With that info, no signs of leaks. my problem is fridge isn't cooling at all and has check light on instantly in both modes. gas or electric. Why??
SOURCE: We have a Chef GSC6638S
Check the oven ignitor may be its weak ,unable to draw enough ampege to glow. or your safety valve is shorted.
Hi there
Sounds like a common problem
when you plug the power pack into the laptop its power light goes off because there is a fault. Most commonly this is connected with the plug or the socket into which it goes or the motherboard.
visually inspect the socket, if the central pin is loose thats your problem, if not then check the plug/jack bend the cable on it as these are prone to breaking. wiggle it around whilst checking the power button and status lights if none of that works then you need to strip the laptop and perform a continuity test on the first stage.
ie between socket and motherboard. please note for any sign of exposed cable and remember electricity hurts on contact be carefull. especially if you test motherboard for voltage.
ps the switch is pretty reliable and i would not poke anything in that hole just yet.
SOURCE: Norcold model number N621 won't power on
its difficult to explain the dc are going to the thermostat and from the thermostat to a element that warms the outside to make cold in the inside does it have a pc board or not be free to ask questions
SOURCE: Monitor goes blank randomly
It is the capacitor on the power to the monitor. I have replaced about 5 so for. The capacitor is like 69 cents. Open it up and look at the circuit board where the power plugs into and see if any capacitor are bubbled up. If so then its a bad capacitor.
SOURCE: Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
