Question about Jamo Audio Players & Recorders
How to connect a jamo sw410e subwoofer to an esoteric az-1 amplifier? Somebody can provide me any help on this?
Posted by Roberto Acosta on
3 Related Answers
Dennis McCollum
  • 137 Answers
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Posted on Apr 20, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: i have a 2 channel
Refer to the applicable Jamo manual.
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/313.aspx
Posted on Jun 02, 2011
technical114
Stelios
  • 1851 Answers
SOURCE: I have a JAMO SW410E
Sorry to said but Jamo SW410E is an active subwoofer. This means that is has his own amplifier for the speaker (that why you can see at the back panel of the sub the RCA connectors for Left and Right (line in level):
In the meantime your Panasonic SA-PM19 stereo system has none connector for audio out (except the one for the heaphones). So it's not possible to connect these 2 audio devices together.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 03, 2011
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
I have a JAMO SW410E subwoofer and would like to connect it to my Panasonic SA-PM19 stereo system, Im not sure if its possible but I would like to know if i can and how to do so. Thank you.
Thanks and regards
Stelios
Aug 03, 2011 | Panasonic Audio Players & Recorders
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
May 21, 2011 | Jamo SUB 1810 Subwoofer
Sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Mar 29, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Mar 15, 2009 | Jamo SW400E Speaker
324 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
