Question about Kodak Photography
Kodak Easyshare digitalframe s730. I would like to add new photos to it, but when I try to do so - I get a prompt that the frame is writeprotected. The frame has about 750 MB free space Please help :)
Posted by Tine Pedersen on
5 Related Answers
Mark Healy
  • 3 Answers
SOURCE: "formatting problem"
I had a similar problem, I could upload songs, but they wouldn't play and I couldn't delete them. turned out it was cause I didn't have WMP10 installed on my PC, had an older version. the user manual states it only works with WMP10, and after I installed it (just search for windows media player 10 on the microsoft website) I was able to use the synch function in WMP10 and all the songs are playable (I'm listening to an album as I type :D)
Posted on Dec 27, 2006
Anonymous
  • 85 Answers
SOURCE: Sansa C150 No Space for DB. Please free more than 4.0 MB
are you able to format the player while in msc mode?
right-click on it while in my computer and select the format option, make sure your selecting your mp3 as this will delete all the files off the device. It if says failed to format, try doing it thorugh disk management. To get there you can right-click on my computer and select manage from the drop down menu. From here you will see disk management on the left hand side. Then a larger rectangular box with the drive letter that represents your player, you can right click on this and select format.
Or just try a different computer, if its the same everywhere then youll probably have to end up emailing sandisk, stating everything you tried. They will probably ask you to do a couple more things, but if you keep at it, youll end up with an RMA*.
*RMA = Return Merchandice Authorization
Posted on Jun 21, 2008
Anonymous
  • 32 Answers
SOURCE: I have a Kodak Easyshare C530 how do I transfer pictures from computer to camera?
hey, yes you can transfer pictures from the computer to your camera...you take the memory card from your camera and insert it in your computer (if you do not have the slot to insert the memory card you cannot transfer pictures) thn sync pictures to the memory card and then insert memory card back into camera.
Posted on Jul 19, 2008
Anonymous
SOURCE: Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
Posted on Sep 17, 2008
Anonymous
SOURCE: Kodak EasyShare software won't connect to digital photo frame
I had some problems with wireless connectivity with the Ex1011. It turned out to be the connection was breaking when I used WPA security. When I went to WEP it worked fine. My suspicion is that the router was changing the Key over time and the frame wasn't following it. So it would work for a while then stop. But also had trouble even seeing it at times. Anyway, worth a shot. You might try turning off security on the router altogether to see if it makes a difference. Good luck.
Posted on Dec 20, 2008
Do you know if omnitech photo frame model 15242 has a battery compartment
The Kodak EasyShare EX1011 Digital Picture Frame has no battery. To know the complete specification, please click on the link below.
http://store.kodak.com/store/ekconsus/en_US/pd/EX1011_Digital_Picture_Frame/productID.145104900
Hope this helps. Thank you for using FixYa.
Aug 08, 2011 | Kodak EasyShare EX1011 Digital Picture...
I have a kodak easy share photo frame and don't know how to transfer pictures from my computer to my photo frame
Make sure you have installed the Kodak digital display Software then you can just drag and drop the pic to your pc or vice versa
Dec 24, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
Downloaded Kodak easyshare 8 and now the easyshare software will not open.
Follow the steps bellow to resolve this issue:
1) right click on the kodak icon on your desktop
2) left click on properties then click on the compatibility tab
3) uncheck all the boxes the hit apply then ok the keep the changes
4) also try checking if the program was just minimized on your taskbar
Aug 16, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
The Kodak easyshare S510 frame is down
I think you have no option but to have your frame repaired by kodak, you can contact their support line at 1 800 235 6325 use ext. 14
Jun 17, 2009 | Kodak EasyShare EX1011 Digital Picture...
Problems with downloading
Delete the one you downloaded.
Disconect camera from usb.
Re-Download and wait , after re-boot.
Open easyshare wait. conect camera to usb.
Read again manual and help topics.
Vitally
Jan 26, 2009 | Kodak EasyShare EX1011 Digital Picture...
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
Dec 05, 2008 | Kodak EasyShare EX1011 Digital Picture...
New kodak easyshare5500
Maybe you can re-stall / go to start /control panel /go to add remove , find Kodak Easyshare remove and ...restart your computer and re-install the cd's to the Kodak Easycare, Dont for get to re-boot at any time you install any cd's that came with your computer.
Nov 27, 2007 | Kodak EASYSHARE 5500 All-In-One InkJet...
Photography Logo
281 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
