Question about Honeywell Heating & Cooling
My Honeywell thermostat still says batt low even after I changed the batteries.
Posted by Mary Zuleger on
Mike OttawaEstate
Off position then reverse batteries polarities and wait 5 sec. Then place new batteries back to normal position.
Posted on May 23, 2020
Tom Chichester
    Top Expert:
  • Honeywell Master
  • 55,379 Answers
Replacement batteries could be defective or installed incorrectly
Posted on Oct 11, 2018
4 Related Answers
B J
SOURCE: Even after replacing the battery, the programmable
Turn control to off. Remove the batteries for at least one hour. If the display message still reads "bat lo", leave control off, batteries out, and disconnect the red wire on back and wait another hour. Reconnect red wire, put new batteries in and turn system on. It's like a reboot.
Posted on Apr 13, 2010
ADRIAN
  • 313 Answers
SOURCE: nimh batteries give low batt signal even when
the trouble with rechargable batteries is their voltage is low to start with even when charged. they only give 1.2 volts each instead of 1.5 volts from proper AA bateries. I use Energizer Lithiums in all my camers and they are great and last a long time. You can find cheap suppliers on eBay I use a site called 7dayshop.com in jersey (europe).
Posted on Jul 25, 2010
Heath Moyer
  • 767 Answers
SOURCE: I changed the batteries of
Hello my name is Heath it will be my pleasure to assist you. Take the new batteries out and let the display go completely blank then reinstall the new batteries and the lo batt light should go off.
Posted on Nov 08, 2010
R.T.C.
  • 88 Answers
SOURCE: Our Honeywell programmable thermostat T8132A 1049
The T8132A thermstat requires 2 AA alkaline batteries for operation as the T8131 uses the 24VAC souce transformer with battery back up. If new batteries did not fix the problem follow product user manual to reset and program the thermostat. This should clear any errors or problems. If the problem persists then replace the thermostat. If you do not feel confident you can accomplish the task then you should call a licensed HVAC technician to troubleshoot the issue as the wrong settings could potentially cause permanent damage to your system.
Link:
http://s3.pexsupply.com/manuals/1287594709924/40775_PROD_FILE.pdf
Posted on May 09, 2011
Heat not coming on. battery died.
Please go to the link and check graph "2.5 Installing the Batteries". Its really easy so it should be a piece of cake.https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf
Mar 30, 2014 | Honeywell RTH230B 5-2 Day Programmable...
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
Our Honeywell programmable thermostat T8132A 1049 1 controls a Gasglo gas central heater. An old battery leaked onto one battery contact; even with new batteries the BATT LO message came up. After...
Link:
May 09, 2011 | Honeywell Programmable Thermostat Heater
I changed the batteries of the Honeywell thermostat and on the screen it still shows low battery.
Nov 08, 2010 | Honeywell Heating & Cooling
Everytime i replace the battery in my thermostat it says low battery
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 22, 2010 | Honeywell Programmable Thermostat Heater
Even after replacing the battery, the programmable Honeywell thermostat still shows "Low Batt."
Jan 26, 2010 | Honeywell Programmable Thermostat Heater
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
Batt Lo Displayed. I replaced with new batteries. The display still reads Batt Lo and I cannot changed temperature, etc.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,588 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
