Question about Boston Acoustics Audio Players & Recorders
I need to find out what is the impedance for my 10 inch driver/ speakers on my VR970 boston acoustic tower speakers. Is there a way I can find the impedance of these 10 inch drivers?
I have Boston Acoustics Tower Speakers - VR970 which is the 3-way, powered floor standing loudspeaker with system-specific crossover and a 125-watt integrated amplifier with 10" powered subwoofer.but not manufactured any more unfortunately. Unfortunately due to moisture setting in the driver/ speaker has been destroyed. I ned to buy new drivers, but do not know if the IMPEDANCE of the speaker is 4 Ohms or 8 Ohms.... is there any way I can get that information? Please Help
Posted by Amal Prasad on
5 Related Answers
Anonymous
  • 101 Answers
SOURCE: NEW BOSTON ACOUSTICS SX65 6.5 CAR AUDIO SPEAKERS
and?
Posted on Jan 22, 2008
Anonymous
  • 7 Answers
SOURCE: Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Posted on Feb 23, 2009
Robert Rankin
  • 378 Answers
SOURCE: 250W, 8 Ohms speakers on 150W, 6-16 Ohms Amplifier.. What is the effect of this?
If your amp states that it will support a range of 6 - 16 ohms, an 8 Ohm speaker will work fine on it. If the speakers you hook up to it are lower than 6 ohms, it may work until you turn it up, then it will either shut down or burn out the finals. If you hook up a speaker that has a higher than 16 ohm, it will not get very loud, and it shouldn't hurt the amp.
Posted on Feb 16, 2012
Wayne Holden
  • 512 Answers
SOURCE: what is the impedance of the JAMO A3SUB.3 speaker?
22K is the impedance listed in the specs but you may have to look on the actual speaker itself to get the impedance of the physical speaker.
Posted on Sep 16, 2012
jturcotte
Jeffrey Turcotte
  • 8984 Answers
SOURCE: On back panel impedance for 2 speakers is 4-16 ohms. I run a pair of 6 ohm speakers with receiver and this is find. I want to connect 4 speakers all 6 ohms impedance and need to know if this is safe f
Stephen, it may depend on how the system is protected, but generally the protection is designed to prevent the transistors from overcurrent. This would happen if you turn the volume up too high. If your receiver is newer--say built after 2005 or so, it will likely protect itself. You can hook up your speakers and see if it works. It will likely trip the internal protection at high volume, depending on the amplitude of the music signal. My main warning would be to not run the volume high for long periods and make sure there is nothing blocking the cooling vents on the unit.
Posted on Jan 14, 2015
Boston Acoustics CS26 Speakers sound cuts out for over a second at higher volumes tested using two different amplifiers same problem. Does not seem to be related to amp distortion:clipping protectio
It sounds like the speaker cones(if that is what they have) get hung up against the back of the case. No vibration=no sound. Check to see that there is no hum adding to the pressure on the speakers. Check to see that the speakers are hooked to the correct impedence output of the amplifier. Also, wire length affects impedence and shortening the wires might help.
Jan 22, 2013 | Boston Acoustics CS26 Speaker
Drivers Boston acoustics
Looking up these speakers, it appears that they connect via a 3.5mm headphone jack. This type of interface does not require a hardware driver. Instead you need the driver for your sound card, download the driver from the website hosted by the manufacturer of your computer.
please rate my solution
Jul 21, 2010 | Boston Acoustics BA265 Computer Speakers
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
What kind of cables for Boston Speakers?
You want stranded wire, speaker wire, 14 - 12 gauge
Oct 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Boston Acoustic BA735 no sound on new hp computer
All you need to do is download and install the Vista drivers from Boston Acoustic. You should then be all set. Hope this helps.
Sep 06, 2009 | Boston Acoustics BA735 Computer Speakers
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
59 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
