Question about SanDisk Sansa m240 MP3 Player
I don't see list of music in windows media player Sansa mp3 240 1G - I want to delete some songs and add a few others - how do i delete some of the music
Posted by jebank_2000 on
Anonymous
  • 63 Answers
Just go to my computer open up your device, it will probably be removable disk, then if the music files are not there look for a music folder, or do a search for music files and identify which folder the music goes in, if its not the root folder
thanks, dont forget to vote
Posted on Aug 03, 2009
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | SanDisk Sansa Clip MP3 Player
How to delete songs
There's no way of directly deleting a song on the player. You need to do it either via Windows Explorer, or a music manager program which "syncs" to your player.
To delete a song via Windows Explorer, connect your Sansa to your PC, open up "My Computer" (or "Computer" if you're running Vista), and you should see your Sansa listed there. Double-click on it. If you then see "Internal Memory", double-click on that. You should then see a list of folders including "Music". Double-click on that, and you should see a list of songs. If you see a list of folders named after your Artists, double-click on the appropriate Artist folders to find the songs you want to delete. Select the song(s) and press "delete" on your keyboard.
If you use a music manager program such as Windows Media Player, Media Monkey or Winamp to sync music onto your Sansa, just delete the song from the music manager library or playlist(s) you're syncing to your Sansa, then do another sync.
Feb 17, 2010 | SanDisk Sansa e200 MP3 Player
Sansa e260 has no space left to write the database info. Vista and also Windows Media Player don't ''see'' any files. I can listen to all the music on the MP3 but I want to delete some and add others.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Start over put new songs on it
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
My sansa won't play the music files
That is the problem with WMA's - they are glitchy, the licenses expire after a while, and the songs you paid for are no good if you allow your music service subscription to expire. You actually have to renew the songs through Rhapsody, delete the existing ones after your Sansa, and then re-sync them through Windows Media Player.
If you only download and transfer songs in mp3 format, they will never give you this problem.
Mar 26, 2009 | SanDisk Sansa e250 MP3 Player
IM TRYING TO DELETE MUSIC FROM MY MP3 PLAYER
Windows Media Player is the program you will be using to delete files off your Sansa. To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
if (!window.netshel_ord) { netshel_ord=Math.random()*1E16;} if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++; window.google_render_ad();
Mar 23, 2009 | SanDisk Sansa e260 MP3 Player
Adding songs
When you sync, you are telling Windows Media player to make the player match what is currently in your sync list. So if you removed the first 110 from your Windows Media, that is why they disappeared from the player.
You don't need to use Windows Media player to add songs. Simply open Windows explorer, double-click your Sandisk device, double click the music folder, then drag and drop any files you want into the folder.
Dec 31, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e250
If you want to delete EVERY track off the player, then reformat the player in Windows Media Player - it's a shortcut - see my "tips and tricks" on formatting mp3 players
If there are artist, album traces, then you need to click on every subfolder under your device in Windows Media Player and delete every trace that way - tedious, but effective
-Tha Mp3 Doctor
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 04, 2008 | SanDisk Sansa e250 MP3 Player
Remove Songs
sync mode in windows media player is used to add in music, to delete songs, on win media player 11 click on library and then on the left side of the player there should be a list, on the list should be "Sansa C240", click on that and then find the your music, right click and delete. Or you can always click on the arrow below "sync" and then go to format to delete all songs.
Jan 18, 2008 | SanDisk Sansa c200 MP3 Player
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Apr 27, 2007 | SanDisk Sansa e260 MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
147 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Muntejaya Ginting
Muntejaya Ginting
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
