Question about Kodak EasyShare C513 Digital Camera
Wont turn on brand new batteries in
I took the batteries out of my camera while it was still on now the lens wont go back in and the camera wont even turn on what should I do?
Posted by kentonmayfie on
jamie
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Throw it away
as somone has droped the camera when it was turned on
Posted on Aug 03, 2009
It started failing after a few shots in that it wouldn't retract as if the batteries were run down.Now it wont activate even when brand new batteries are put in, It merely flashes with the red allert light...
What can happen is the lens on them can go ofsidded, if the lens is not retracting back in give it a firm push untill u hear a click and turn off and on, hope this helps in some way.
Dec 01, 2009 | Kodak EasyShare C330 Digital Camera
Lens wont retract into camera
Sounds like the lens barrel has been damaged. Does it look as if it's pointing slightly sideways or is it not perfectly round anymore?
Aug 12, 2009 | Kodak EasyShare C913 Digital Camera
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Tried uploading pics on computer now my camera wont turn on or off...did i break it..is there a virus???
I had the same problem. I took the battery out for 30 seconds and put it back in. I then turned it to the view mode, and turned the camera on. Hope this helps.
Oct 14, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
Polaroid i834 wont turn on
Same problem; however, after taking a hard look at the camera I noticed that the lens was tweaked; that is, is was not evenly extended so I pulled (by hand) on the inner, extended lens piece and viola; I turned it on, the lens retracted and extended upon application of power as usual.
My guess is the 3 beeps is much like a BIOS error with a PC...when there is a hardware problem they beep on startup...in this case, the camera was letting me know the lens was stuck.
HTH
Mar 23, 2008 | Cameras
Kodak EasyShare C513 Digital Camera Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
