1, The 003-302 error in the Xerox 6050A printer indicates that the machine is stuck with paper jam and paper feed problems. Set the printer turned on for a few minutes.
2, The internal fan cools down all the hot parts. Remove the paper tray from the printer completely. Observe the inside of the printer keenly and remove all the jammed papers. Do not touch the printer's internal wiring. Papers may also be jammed under the printer bed due to static electricity.
3, To remove them, locate the green-colored levers on the edges and pull it. The roller shows up. If you find any papers on the roller, remove them. Close the rear panel until it reaches the lock position. Open the front panel of the printer.
4, With reference to the printer's manual to discard the toner cartridge system and the drum unit assembly. Make sure to remove all the jammed and torn piece of papers from the inside.
5, Close the access panel and reload the input tray with a new set of genuine papers. Check if the issue resolves.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220.
