SOURCE: Input audio to PV-GS250 from an external mixer
Problem check list:
- Try another cable in the connection to rule out the cable
- Make sure the 1/8 plug goes in all the way
- Make sure you have it connected to proper outputs on the mixer (and that it's not a powered mixer!)
- Make sure you don't have the output volume up too loud on the mixer
SOURCE: Tapco MIX60 6-Channel Mixer
It does not appear to have a crossfader
Check this link for a closer look at the mixer. You can click the "larger image" link and get a really good look at it. Unless one of the knobs are a crossfader, but I always seen sliders as a crossfader. At least you can see it better here.
http://www.bswusa.com/proditem.asp?item=MIX60
SOURCE: home stereo audio problems
I've had some progress, have tried 2 different amps and 2 different mixer now... The weird thing is, if I plug a turntable directly into the receiver, everything is great. Once I connect the record player through a mixer and then to the receiver, I can get sound, but its really bass-y and buzzy and essentially just terrible... Such a weird problem...
SOURCE: Kitchenaid mixer professional motor
DO NOT DO IT. The Hz will destroy the morotr. The transofrmer only converts the voltage. You are better off buying a 220V version.
SOURCE: What type of graphics card to buy for an emachines EL1600
Any chance you can send an image of your system board and the graphics card. Chances are if you system board is older that it doesn't have a PCI express slot.
If this is the case you need to either upgrade your system board or exchange the graphics card for a standard PCI or AGP graphics card.
