Cooktops Logo
t
tricia harris Posted on Oct 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cooktop hot surface light stays on and the biggest burner flashes error F153 and does not work. Other burners work. Can this be fixed?
Chris Huff
Level 3:
Top Expert:
  • Master 6,289 Answers
  • Posted on Oct 09, 2018
Chris Huff
Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017843
Points
74913
Typically a bad infinite switch will cause hot surface light to stay on. I would start by testing the switch for the burner that doesn’t work.
jackdnimble
Level 2:
Habit-Forming:
New Friend:
  • Expert 112 Answers
jackdnimble
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
112
Questions
Helped
87365
Points
415
Hi Tricia, I assume this is a GE unit?
Check this link from Appliance Blog that deals with this problem.
Appliance Repair Forums
2 Related Answers
A
Anonymous
  • Posted on Oct 15, 2007
SOURCE: cooktop light stays on when cool
Please be more specific.
A.  What is the "plate cut-out"?
B.  How does one access it?
Anonymous
  • Posted on May 29, 2009
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
1helpful
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
1helpful
May 21, 2009 • GE Cooktops
10helpful
2answers
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
1helpful
2answers
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
