GE is made by Rheem ... and the heater has a thermal device located inside combustion chamber that trips when heat inside combustion chamber exceeds approximately 180°F. Tripping off can be caused by ignition of flammable vapors or by malfunction of vent, incoming air supply, dirty combustion parts, or failed thermostat on gas control valve.
Following link has troubleshoot and repair steps:
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
SOURCE: takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
SOURCE: GE Smart Water Heater - Model #GE40M06AAG - 40
There should be a faucet on the side . you hook up a garden hose and drain it.
SOURCE: GE Smart Water Heater Model# GE50M6A. Hot water
Your bottom element is burned out. You will still get hot water from the top one, but like you said, not nearly as much.
Do a search for "appliance parts" and then enter your model number and you will be able to purchase the aprt online. Check a number of different sites as the prices can vary greatly. Many of these sites will have exploded views, so that you can see how they come apart and go back together. Wire the new element in exactly as you remove the old one. The bottom one will only have two wires so it is very easy.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
SOURCE: I have a 40 galon
I believe this unit does not have a standing pilot light and lights each time? Have you reinstalled all doors back into the heater? It sounds like the main burner is blowing the pilot off the thermocouple. You might try replacing the thermocouple. You can download a manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=SG40T12AVH00
SOURCE: I have a GE hot water heater, SE40M12AA01, dual
1) You posted under Rheem-GE electric water heater.
If upper element is burned out, then water heater will not heat any water.
http://waterheatertimer.org/How-it-works.html
2) Replace upper element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Open following link for complete troubleshoot:
This troubleshoot assumes you have standard thermostats and elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
4) Manuals and links. I do not see 'smart lights' in the manual.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Standard_Water_Heaters
Troubleshooting starts page 15.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=AP12168-7%20%28GE%20Elec%29.pdf
5) Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
