Question about Chime Home
I have a Sligh grandfather clock and I only want it to chime on the hour instead of every 15 minutes
I want to know how to set the chimes to only strike on the hour instead of every 15 minutes. I have a levers at the 3 and 9 position of the clock. I believe the lever at the 3 is for which chime to sound and the lever at the 9 is for the sound.
Posted by Pamela Schuld on
5 Related Answers
Anonymous
  • 714 Answers
SOURCE: my new wall clock chimes 2 minutes BEFORE the
You will need to do a mechanical adjustment to the hand.
Loosen the hand nut and adjust the hand the tighten.
Hope this tip helps to solve your problems
R/
David
Posted on Mar 19, 2010
Testimonial: "i will try this. thank you so much"
small6363
  • 18429 Answers
SOURCE: Elgin Anniversary clock chimes early
take the big hand off and move it back one square on the shaft
Posted on Nov 12, 2012
george6roble
George Robles
  • 49 Answers
SOURCE: Halo Grandfather Clock won't chime hour
In my eyes there are two kinds, ones that are a real grandfather clock that runs on gravity using a series of weights and gears with different counterweights for chimes and running the clock itself, and there are the show pieces that look like a grandfather clock but run on newer tech and electronics. If a real one then would try first pulling the weights to the top. They are usually shaped into a pinecone or something. If weight is at bottom them have to pull corresponding chain with weight till the weight is at the top of case. As "time" goes by the weights lower. You should have different counterweights for the clock, chimes, dancing figures and whatever else it may have. All the weights move at different "speeds" so you have to keep an eye on them to make sure it keeps correct time. I would recommend consulting the manufacturer if possible. There are so many kinds out there is really hard to tell by such a short video.
Posted on Dec 16, 2014
srr_robin255
  • 37 Answers
SOURCE: Gazo Rancho Santa Fe Grandfather Clock won't chim
Check the wires in the back.some times the get corrodes.
Posted on Dec 18, 2014
SOURCE: I have a Seth Thomas
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Posted on Feb 24, 2017
How do I change the time on Grandfather clock. Chimes are different
Jan 14, 2017 | Home
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
Dec 17, 2014 | Home
My wm widdop clock chiming out of sequence
Oct 21, 2014 | Home
How to adjust Grandfather clock that chimes one chime less ?
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
Oct 04, 2014 | Home
How to reset a chime clock
Jul 10, 2014 | Home
I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
Thanks for contacting FixYa.
I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
http://clock-repair.net/site-map/seth-thomas-clock-repair/
Best regards. Jewel
Sep 13, 2010 | Watches
Home Logo
127 people viewed this question
Top Chime Home Experts
Marvin
Marvin
Vernon Taylor
Fahr Quad
Are you a Chime Home Expert? Answer questions, earn points and help others
