Question about Ultra Computers & Internet
Try some free PwerDVD alternative such as Leawo Blu-ray player that has been developed with forefront decrypting processes to bring out any video movies regardless of the region codes.
Posted on Mar 01, 2020
Is that version compatible with win 10
if it is not , that will be the basis for your problem
Posted on Oct 09, 2018
SOURCE: Can't Install Windows Media Player 10
If Windows Media Format 11 Runtime is listed in Control Panel under Add or Remove Programs, you will receive this error. You must uninstall Windows Media Format 11 Runtime before you can install Windows Media Player 10.
Posted on Feb 06, 2009
SOURCE: Latest Windows live messenger won't let me use my webcam
Normal 0
See section C. Windows LiveMessenger in the info below to setup the Audio & Video.
Also send this to your familyand friends so they have there computer setup properly.
Web Camera’s have to besetup on the program they are to be used with. Just installing the camera on your computer does not set it up tobroadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
C. Windows LiveMessenger:
Go to thissite http://download.live.com/?sku=messengerand download Windows Live Messenger.
NOTE: Your audio andvideo should work. Enjoy.
When done both the Audio and Video will function properly soyou can chat and see family or friends you are connected to.
Hopethis helps. Bud
Posted on Mar 28, 2009
SOURCE: I have installed Cyberlink Power
This is happening to those who used versions of the meadow.
It was contained in previous versions of DirectX-a.
You can check the place of this file in your Cyberlink installation folders and can replace it with new one which you can download from internet or you can copy a new one there.
But best solution is to check your directX driver is up to date or not.If not you should update it and then try to install Cyberlink again.
Good luck
Posted on Apr 12, 2009
SOURCE: unable to install a new powerdvd version
You can uninstall PowerDVD from either Windows Start Menu or the Windows Control Panel. 1. Click " Start">- " Programs" >- " PowerDVD" >- "Uninstall PowerDVD", the uninstall wizard runs. Then you can follow the uninstall wizard to remove the program. 2. Click " Start" >- " Control Panel", and double- click " Add or Remove programs". Select PowerDVD, then click Change/ Remove. The PowerDVD will automatically be removed
Posted on Jun 08, 2009
SOURCE: My printmaster Platinum 10 version will not install on Vista.
I was able to get PrintMaster Platinum 10 to install on Windows Vista by right clicking on E:\Setup\is_Setup.Exe->Properties->Compatibility->Run this program in compatibility mode for Windows XP (Service Pack 2) and then running E:\Setup>is_Setup.Exe FullSetup.ini from the command prompt.
Posted on Apr 04, 2010
Mar 13, 2016 | Apple iTunes
Oct 04, 2014 | Computers & Internet
Nov 09, 2013 | Lenovo Computers & Internet
Dec 10, 2012 | CyberLink Power DVD 10 Ultra 3D
Dec 08, 2012 | CyberLink Power Dvd 10 Standard pc
Jan 24, 2011 | Computers & Internet
Feb 03, 2009 | 2000 Ford Windstar
Sep 28, 2005 | Apple iPod nano
Oct 25, 2018 | Ultra Computers & Internet
81 people viewed this question
