1, I have samsung C430W printer..I replace the transfer imaging unit but still it showing to replace it..how can I reset the page count of transfer imaging unit...please help...
2, Turn Off the Samsung C430W printer using its Power button or disconnect the power cord from the back of the device and also from the wall outlet. Else, turn Off the switch present near the socket. Wait for about a minute. Replug the cord between the printer and the outlet. Power On the device and verify if the problem is solved.
3, To reset the page count, Click the Reset Fuser Life button and then choose the OK button, this resets the fuser. If the error is not rectified, the imaging unit has to be reinstalled or replace it with a new one again.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
SOURCE: Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
SOURCE: reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
SOURCE: Samsung CLP 510 Imaging Unit
The Imaging unit needs to be replaced when the drum fills up with waste toner. That's what triggers the message.
SOURCE: Dell 1720 flashinf replace drum- error.
I believe this message is occur because the laser printer drum needs to be replaced, not the toner cartridge.
These are two different things. The part is a DELL 310-8710 Drum Unit. Just google DELL 1720N drum and you should be able to find one.
