Question about HP DeskJet Office Equipment & Supplies
Why is HP Deskjet Printer 6988 showing blue exclamation point & yellow cartridge symbols?
Posted by Mary Sekera on
5 Related Answers
Anonymous
SOURCE: exclamation point
That's the notification icon. It indicates that you've "received 2 or more different types of notifications: Voice Missed Calls / Schedule / Call Alarm / Alarm Clock".
Check your Missed Alerts on the phone menu, your alarm clock settings in menu > tools and failing that, try going back through your calendar to see if you've missed any meetings or something there.
Posted on Jul 18, 2008
Anonymous
  • 31 Answers
SOURCE: yellow horshoe light with exclamation point in middle
thats your TPMS light, Tire Pressure Monitoring System. The light means that one of your tires is low on air, so check them all and fill them to the specified amount, which will be located on the drivers side door jamb.
Posted on Dec 12, 2008
Anonymous
  • 7 Answers
SOURCE: facebook chat has yellow triangle with exclamation point in it???
This happens when you lose your connection, refresh the page and you should be able to continue chatting.
If this doesn't work, then facebook might be doing some maintenance work on their chat module.
Posted on Mar 26, 2009
super_guy
  • 1986 Answers
SOURCE: cell phone charger looking symbol with an exclamation point
Could be the tire pressure monitor system...
Posted on Aug 13, 2009
Testimonial: "SuperGuy, thanks for your help! That's exactly what the problem is! The picture is a little whack for a tire monitor but you were RIGHT! "
emissionwiz
Marvin
  • 85239 Answers
SOURCE: I have a 07 sonata a yellow horse shoe symbol with
this is the low tire pressure warning. refer to the owners manual, make sure the tires are set to proper pressure including the spare tire.
Posted on Oct 14, 2009
Testimonial: "thank you I found this to be very helpful and will check my tire pressure thanks pete"
I have an HP 6988 printer, will not print because is states out of black ink. I have replaced the cartridge for the second time now thinking I might have ourchased a defective one however it still states...
I would take the cartridge out, and use a qtip with a bit of rubbing alcohol on it to clean off the contacts on both the cartridge, and the corresponding one on the printer itself. It seems as though the printer is unable to get a signal from the cartridge so it is just displaying a generic 'out of ink' error.
May 29, 2011 | HP DeskJet 6988 Printer
Plastic piece in front of the cartidge prevent cartridge removal
Please have a look at this support tutorial. I think you will find that the plastic piece is the cartridge latch which holds the ink cartridges in place.
HP DeskJet 6988 Replace Cartridge
Jan 09, 2010 | HP DeskJet 6988 Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Cannot install new color print cartridge for HP 6988
Do NOT force it! Ensure you're following the manufacturer's directions: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=130&prodSeriesId=468002&prodTypeId=18972&objectID=c01129395
Oct 28, 2008 | HP DeskJet 6988 Printer
Left light blinks and i can't print anything
Open the cover of the printer, carriage will move out. Upside it you see a yellow arrow showing to on of 5 symbols. Left symbol means empty color cartridge, second symbol means empty black cartridge
Mar 11, 2008 | HP DeskJet 940c InkJet Printer
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
