Question about Mercury Boating
2006 60 horsepower mercury outboard motor manual 4 stroke
Need a manual for 4 stroke 6o horsepower mercury outboard
Posted by Jim Langley on
5 Related Answers
Anonymous
SOURCE: homelite 4 cycle outboard motor parts
I have 2 homelite 55 HP for parts, every thing but rods, and in very good clean condition.
What do you need?
Tom Tompkins
Portland, OR
503-645-4227
Posted on Oct 22, 2008
Anonymous
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Posted on Jul 05, 2009
Anonymous
  • 86 Answers
SOURCE: 2003 yamaha 115 outboard motor that dies when
I would check your fuel lines from the tank all the way to the fuel pump. It seems that you might have a pinched line somewhere. You can also bleed the fuel rail with the schrader valve on the end of the rail. If that wont fix it then you probably have a weak fuel pump.
Posted on Aug 09, 2009
Anonymous
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
What year is my mercury outboard searial no 3768233
Check here, you'll need the horsepower and lookup the serial-number range...
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 31, 2014 | Mercury Impeller, Water Pump - for...
What type of petrol is needed for a yamaha outboard motor horsepower 8?
reg unleaded gas.
You haven't specified as to its year of manufacture, so if its older, as in a 2 stroke, it'll be a mix of gas and outboard oil.
If its a newer model, a 4 stroke, it'll be injected(Gas and oil seperate)
If you are totally unsure, Consult your owners manual and if you have none, then any Yamaha dealer can use the serial # off the motor to establish any specs on it for you.
Happy boating.
Oct 04, 2009 | Boating
Boating Logo
202 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
