When I press it it doesn't move the cursor justgoes to shooting mode and backagain
SOURCE: Canon Rebel will not shoot in AF mode
the mirror is problem of your camera,it alway been close that why the sensor is functioning properly cause that sensor is working in af mode....check the post at the side of the mirror if not broken and the spring of the mirror if not dislocated....doing this you should removed the lens from the body......
Posted on Aug 26, 2007
SOURCE: some of the buttons don't work
I just had the exact same problem with my TZ1. I sent it to DK Audio Visual Services in UK. They opened it and cleaned the Circuit Board. Now everything works fine. The damage? 75£ or something lie 150$ That is not so bad considering that the new TZ5 is sold at 400$ and more...
Cheers.
Dominic Lemoine
Posted on Jul 17, 2008
SOURCE: How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Posted on Feb 15, 2009
SOURCE: one of the buttons on the monitor doesn"t work
To solve an OSD lockout problem just follow one of the four fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Posted on Apr 12, 2009
SOURCE: the left mouse button on my laptop isn't working
Go To Start-> Settings-> Control Panel-> Mouse - Check All Options Are As U Wish Then Try Unplugging It Restart Pc It Should Work...
Posted on Nov 21, 2009
