Question about Furniture
My wine cooler 272 03 12 has a flashing EH code what is the fix.
Posted by Gordon Klemp on
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
mcnutt10
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Posted on Jan 01, 2009
Anonymous
SOURCE: electrolux wine cooler ''af'' code flashing
Believe it or not we had the same problem.... The air filter should be changed about every six months but it is just charcoal or baking soda or something like that and is not attached to any sensors. To reset the flashing light, make sure the control panel is unlocked then hold down the on/off and (-) buttons and it will reset.
Good Luck! Elisabeth
Posted on Sep 01, 2009
Anonymous
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Posted on Feb 17, 2010
Anonymous
SOURCE: E5 flashing error code
I have the same error on my U-Line beverage refrigerator. U-Line said the error indicates the thermostat was out of range for over 12 hours (perhaps due to a recent power outage). My fridge seems to be working just fine so I am not planning on calling a technician until something more serious breaks down.
Posted on Aug 11, 2010
I have a igloo 48 bottle wine cooler, and it will show error code "LC" and then you can not adjust the digital temperature or turn the light on. It fridge still feels code? Any ideas would be great!
Could be the temperature sensor. There should be a support number in the manual you can call. Hope you can get it fixed. if not check out my blog for help choosing your next cooler. The Best Wine Coolers The Complete Guide Vino Coolers
Jun 07, 2016 | Furniture
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
Edgestar wine cooler eh error code
You can download the owner's manual at: http://www.edgestar.com/TWR215ESS-EdgeStar-21-Bottle-Dual-Zone-Wine-Cooler/TWR215ESS,default,pd.html?cgid=Wine_and_Beverage-Wine_Refrigerators
Apr 10, 2013 | EdgeStar TWR181ES
Instruction manual for dihl wine cooler 32 bottles
i have a dihl 21 bottle dual control wine cooler. the temperature display keeps flashing and won't set, this is now happening with both top and bottom ... how do i fix it
May 18, 2012 | Refrigerators
Unit was leaking at rear coil, sealed the leak but know it needs freon. Can it be added?
All fridges, freezers, coolers, etc need access ports added to them before any refrigerant can be added to them. Makes you wonder how they do that eh?
May 29, 2009 | Avanti WC54 Wine Cooler
The door was not shut good, so i turned the wine cooler off and defrosted it overnight, but i still have E5 error code flashing.
e-5 means that the unit is 10 degrees warmer then setpoint. If you just close everything up and let it run the e5 should disappear when it gets within the temperature.
Apr 25, 2009 | U-Line 15WC Wine Cooler
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Sep 16, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Jul 13, 2008 | Danby DWC513BLS Wine Cooler
Furniture Logo
819 people viewed this question
Top Furniture Experts
Tom Chichester
Marvin
Marvin
Are you a Furniture Expert? Answer questions, earn points and help others
