Question about Whirlpool Washing Machines
Whirlpool Ultimate Care II Top Load Washer intermittently will not spin. Wife has to bang on the lid a number of times and then it will go. Model # is LSQ8543JQ0
Posted by Bill McDuffie on
Costin Draghia
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Check the contact on the cover.
Posted on Oct 08, 2018
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: LID SWITCH ON WASHER REPLACE.
TEMPORARY FIX for model # LSQ8200HQO (perhaps, other models as well) until you can tear the thing apart: DUCT TAPE. One drawback - you'll have to leave the lid open, tape the lid switch on the outside *away* from the tub. The wires on the model listed are long enough to allow you to do this.
Thanks for helping me figure out what the problem was. Tearing apart will have to wait until Monday ... RUSH CONCERT tomorrow night!!!
Posted on Apr 20, 2008
Anonymous
  • 6 Answers
SOURCE: Whirlpool Ultimate Care II LSQ9549L Top Load Washer leaves water
Water pump must not be running. Check if the belt is not broken or came off or the dial switch is bad or the clutch is not engaging.
Good luck
Posted on Dec 13, 2008
evanusa
Evan Benson
  • 198 Answers
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 01, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
Posted on May 16, 2009
Anonymous
  • 619 Answers
SOURCE: I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Posted on Jan 31, 2010
Testimonial: "The issue turned out to be a worn out clutch. The fix was actually to use a couple of dimes to increase the pressure on the clutch piece so that it would engage the drive hub. 2.5 years later and the thing is still working."
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II will not go into rinse or spin cycle. Motor runs and agitates during wash cycle properly. This problem occurrs on all wash cycles.
The problem is most likely with the lid switch. This washer can fill and agitate with the lid up or down but will only drain and spin with the lid down. If the lid switch breaks the washer does not know that the lid is down so it will not run.
The part number for your model is 8054980 and runs about $20.00, it is shown in the image on this link below as part 11.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0403060-00001.png
Apr 20, 2010 | Whirlpool Ultimate Care II GSQ9669L Top...
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Dec 03, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
94 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
