Question about Planar Computers & Internet
Planar TV PX2710WM CODES, for Xbox 1-s
Im hooking up my Planar TV/Monitor to my Xbox 1-S
Posted by Scott Bruce on
1 Related Answer
Anonymous
  • 56 Answers
SOURCE: x box 1 to pc monitor
there are special units that you can purchase to do this, other than that, there really isnt a decent way, unless you get an lcd with component inputs
Posted on Aug 15, 2007
We moved our tv to anothor room and now all it does is light up the name when turned on. Nothing else will work. Everything is hooked up correctly
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc. Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Oct 16, 2017 | Televison & Video
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Lock out my monitor px2710mw
Here is the user's guide for your monitor:
(from Planar's website)
http://www.planar.com/media/222919/mn-planar-px2710mw.pdf
Feb 18, 2014 | Planar PX2710MW Monitor
What's your problem?Im trying to hook up my xbox 360 to my JVC 27 inch TV, I installed the yellow to video input and the red and white to audio input and all get is the audio and no video. What am I...
Troubleshoot.
1. Ensure yellow is actually connected to an "input" slot.
2. Ensure TV is set to the correct input source.
3. Ensure your yellow, white and red RCA connectors are grouped in a single input source to TV. Sometimes the "component" and "composite" inputs are grouped closely together.
4. Consult the TV manual for hookup instructions.
5. Conduct a continuity test on the yellow xbox wire with a multi-meter.
Oct 04, 2011 | Sega The Club - Xbox360 for XBox 360
Resolution problem
A Chip on the monitor circut board must be reflashed. You need to send back to Planar, do an rma. They were very responive to me, sent me a replacement.
Sep 07, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Buzzing sound coming from monitor speakers
Check your leads, chances are it's a faulty/dodgy lead coming from your macbook to the system.
Jan 14, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Problems with screen
problam can be with cable, screen, or xbox. try replacing cable first, it is the cheapest and therefore can save you alot of pain. if another cable doesnt solve it, try hooking xbox with another screem (TV or something), if it works, its a screen problem - check for overheating. if it doesnt, you got yourself a messed xbox im afraid.
Feb 22, 2006 | Microsoft Xbox 360 Console
Computers & Internet Logo
151 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
C. David Graves
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
