Cameras Logo
Question about Nikon Cameras
I cannot get Nikon D70 to download photos to memory card
Posted by Carol Suitor on
Steve Alexander
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 165 Answers
Nikon D70 is an old camera if you put a new CF in it - it may not work. CompactFlash© (CF) (Type I/II, compliant with UDMA) MicroDrive. So it works with Type I and Type II
Posted on Nov 03, 2018
5 Related Answers
Anonymous
SOURCE: NIKON D70
try tuning the lens.
Posted on Sep 26, 2008
Anonymous
  • 423 Answers
SOURCE: Nikon D70 memory card won't insert all the way
It certainly could be. Without a card in the way, take a look into the card chamber to see if you have a bent pin. They should all be straight up, and a bent one will be obvious. If it's just slightly bent, it can often be straightened with a small jeweller's screwdriver. They are delicate, so bending them repeatedly will break them off.
Posted on Apr 04, 2009
Anonymous
  • 10 Answers
SOURCE: D70 doesn't appear on Mac desktop
This is easily solved.
Most probably the camera's USB connection mode is set to PTP. This is useful for certain situations such as controlling the camera from the computer (you even take photos from OS X's built in Image Transfer).
Change this to "Mass Storage" in the camera settings menu and your camera will behave just like a card reader. Next time you connect it to the computer, plug it it, then turn it on and it will appear on the desktop and in the sidebar as an attached drive.
Don't forget to eject it before disconnecting just as you would an ordinary external drive.
Posted on Apr 21, 2009
Anonymous
  • 51 Answers
SOURCE: Nikon D70 digital camera memory card cannot be used
First read:
http://www.vandyll.net/?p=499
Then read how, with pics:
http://www.stephanmantler.com/wordpress/d70s-camera-repair/en/
Careful now....
Posted on Mar 11, 2010
Anonymous
  • 55 Answers
SOURCE: I have a nikon d70 and just lost several photos on...
You may follow this step by step instructions for how to recover photos from camera
http://www.asoftech.com/articles/how-to-recover-deleted-photos-from-camera.html
Posted on Dec 17, 2012
1helpful
Lexar memory card 4gb premium 60x
If it is an SD or SDHC memory card the answer is yes.
Laptop running Windows7 previously mounted Nikon D70 (camera) as Mass Storage Device but, stopped recognising it. Camera sees laptop?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Nikon Transfer.
Jul 01, 2012 • Cameras
Everytime i connect my nikon d70 to my laptop, there is always a problem with the installation of the hardware.. i can i solve this? is there other way aside from removing the memory card and connecting it...
You can try downloading the camera drivers directly from Nikon's website then see if the computer recognizes the camera, if not you will need to use a different computer to avoid a card reader.
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
1helpful
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Nikon D70 - Random 'Bad' Images
Hmmmm, sounds like a memory card problem.
Nikon D70 Memory
Do you have a memory Card in it?
Line appearing through photo
Nikons do not work well with certain brands of cards. Kingston is one. It could also be a dodgy card...is it new??
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
