Cameras Logo
Question about Nikon Cameras
Nikon D70 does not download images to memory card
Posted by Carol Suitor on
  • Dan Dangel
    Dan Dangel Nov 08, 2018
    Hi Carol Suitor, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    And does you cf card work in a reader with your pc?? ie, can you save and retrieve data using the card when it is outside the camera?
    Has this card worked in the past? (ie, adequate size and speed?)
Jack Guyton
    New Friend:
    Problem Solver:
  • 13 Answers
Reformat your card.
Posted on Nov 10, 2018
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: Nikon D70 won't recognize the 2 GB, type II memory card
Try to clean the contacts of the memory cards and, mostly, of the memory card bay of the camera. Use a dry anti-static fabric (e.g. what we use to clean eye-glasses). DON'T use any liquid cleaner of anything like that!
Posted on Dec 11, 2007
Anonymous
  • 9 Answers
SOURCE: Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
Posted on Aug 21, 2008
Bernie Reeves
  • 395 Answers
SOURCE: opening RAW images from Nikon D70 on photoshop
A Photoshop Raw file is a Photoshop PSD file without a header. The header
information must be entered when the file is imported into Photoshop. The
raw format is used import and export bitmap data using a very simple,
uncompressed binary format.
Posted on Nov 30, 2008
Anonymous
  • 18 Answers
SOURCE: I have a Nikon D70 and am unable to insert memory
STOP! You have just bent a few pins. Your camera has a male connection. Meaning it has pins sticking out. If you are unable to insert a memory card, that means a pin is bent and is not going into the holes in your memory card. This is a common problem with cameras that accept a compact flash card. This can be an easy fix or it can be a very hard fix.
Ive fixed a couple of cameras like this with a pair of tweezers. flash light (or some big source of light) and a magnifying glass. You need to look into the slot on the camera under light and look at all the pins sticking out. Look for the bent pins and use the tweezers to bend them back. Be careful not to keep bending the pin back and forth, as this will break the pin off. Ive seen cameras work without certain pins, but this is not something you want to do.
To have an SLR fixed is a minimum $160 dollars depending on where you take it too. The D70 is a good camera.
Please do not stick the memory card back in. Check the memory card to make sure all the holes are clear and have nothing blocking the holes or make sure a hole has gotten bigger and merged into one. I would use a different card once the pins are are sticking straight.
Hope this helps you.
Posted on Mar 30, 2009
Anonymous
  • 10 Answers
SOURCE: D70 doesn't appear on Mac desktop
This is easily solved.
Most probably the camera's USB connection mode is set to PTP. This is useful for certain situations such as controlling the camera from the computer (you even take photos from OS X's built in Image Transfer).
Change this to "Mass Storage" in the camera settings menu and your camera will behave just like a card reader. Next time you connect it to the computer, plug it it, then turn it on and it will appear on the desktop and in the sidebar as an attached drive.
Don't forget to eject it before disconnecting just as you would an ordinary external drive.
Posted on Apr 21, 2009
Everytime i connect my nikon d70 to my laptop, there is always a problem with the installation of the hardware.. i can i solve this? is there other way aside from removing the memory card and connecting it...
You can try downloading the camera drivers directly from Nikon's website then see if the computer recognizes the camera, if not you will need to use a different computer to avoid a card reader.
2answers
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
I have an early 2004 D70 and am receiving random digital display errors of FEE, CHG, FOR. If I play with removing and reinstalling the battery or memory card they will usually clear but I cannot figure...
Okay the FEE is telling me that you haven't locked your lens in at F22. Lock the lens should be an aperture ring turn it to the smallest aperture and there is a little lock on the side of the lens that will hold it in that position. The camera then looks after the rest. If this is allowed to float then the camera is getting a faults input from the lens. The CHG is a card error, possible you have been deleting images from the card and not formatting the card the card needs to be formatted to the camera.
As a rule of thumb format the memory card in the camera after each time you download pictures to the computer. This cleans the memory card and allows proper communications between memory card and camera. Okay you'll love this one the "FOR" error is a known problem with Nikon D70 and can be fixed by updating your camera firmware on Nikon's site that Otta help. cheers have fun
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
1helpful
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Nikon D70 - Random 'Bad' Images
Hmmmm, sounds like a memory card problem.
NIKON D70
problem in card holder repair or replace
2answers
D70 stuck
Make sure your memory card is OK. Take it out, put it back in or try another card. Be sure battery is charged. Should not see low battery sign in viewfinder or in top panel. Try a reset. There is a problem sort of related to what you describe where a firmware update may cure it. D70 Firmware Update 1.0.1 / 1.0.2 - Windows. One of the problems this firmware fixes is :"When images were captured in Continuous mode at an Image size setting of M and an Image quality setting of FINE, the memory card access lamp sometimes glowed continuously and the camera could not be turned off with the power switch. This problem has been corrected." This bit of advice comes from another Web forum, not my own discovery. Maybe this happened and ran down your battery, unbeknownst to you. Turn the camera off and power it from an electrical outlet. Update the firmware per instructions on the Nikon site. If this does not work or if your firmware is updated, call Nikon for further advice. You may need to have it serviced. This blinking light problem has been mentioned on PN and another forum. Nikon may be familiar with it already.
1helpful
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
