The Coby is weird, but I found a way to create playlists. It might not be the "real" way, but it works :) Before I plug the mp3 in my computer I create folders containing the songs I want for each play list. For example I'd create one folder labeled "work out" for songs I want to listen to while working out, and another folder labeled "sleep" for songs to listen to while sleeping, or you could label them based on artists or genre or etc. Then I would copy the songs I want in each playlist into their respective folders. Next, I plug my coby into my computer, and open it's folder. (should be in computers, and have a icon with a C on it). I'd copy (or click and drag into the coby folder) my play list folders (the ones I labeled work out and sleep). Then eject and remove my mp3. If you do this, when you turn on your mp3 you should select Music. Then select Broswer (on the bottom). Select the first row, which has the symbol "\" [underneath this is all your songs] and you'll see the names of your play list folders (they'll be below ROOT, MAC OS X Coby Me, and PHOTOS) . If you select your play list name you'll see and be able to play the songs under that playlist.
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
NOTE: Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
Try this solution to your proplem
Good Luck,
I hope this helps
Please rate me,
Thank You
This is from Memorex FAQs (not sure if relevant to Coby but relevant to this forum)
How do I remove songs from my digital audio player?
All you need to do in order to remove a song form your player is make sure that your player and computer are in the 'on' position. You will need the USB cables connected as well. Open a window's browser or double click on "My Computer" and find the MP3 player's drive. Locate the song you wish to remove right click on the song and choose the delete option.
If you use WMP to sync, just click COBY MP3 and then you'll see alist of songs. Right click em and hit delete. It will ask if you want to remove it from your list. That's it . The COBY MP3 link is on your left under where it says "library". Hope it helps.
If you're hooking them up via the USB cable, you should be able to just open the player's folder, select the songs you want to remove, and delete the songs from the folder.
