Question about Golf
Where is the solenoid placed on an ezgo golf cart
Posted by Patrick Maritz on
5 Related Answers
Anonymous
SOURCE: I ned a service manual for a 1995 ezgo dcs golf
Our EZ GO golf cart will start and run except you have to hold the choke about half way out for
it to continue to run. What is wrong?
Posted on Apr 20, 2009
Joe Hogan
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
Anonymous
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
golfcartman
  • 34 Answers
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
Posted on Apr 21, 2010
golfcartman
  • 34 Answers
SOURCE: EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Posted on Apr 24, 2010
Ezgo golf cart bucked then died. new batteries and solenoid. What happened?
Does solenoid still click? If it does then I would check the motor wires to see if they are still connected. If ok then I would check the forward/reverse switch assuming you have a Lever type mounted on the body of the cart.
Aug 31, 2017 | Golf
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
https://www.google.com/search?q=1999+TXT+EZGO+golf+cart+controller&oq=1999+TXT+EZGO+golf+cart+controller&aqs=chrome..69i57.1143j0j4&sourceid=chrome&ie=UTF-8
Aug 02, 2017 | Golf
I have a 2005 ezgo electric golf cart, I caused a power surge now cart won't run? What did I blow?
This could be really bad. Start by checking total voltage from battery pack. Next check voltage at small posts of solenoid when pressing pedal. No voltage? start tracing the wiring. Voltage yes? then test solenoid. If good then controller might be bad.
May 23, 2017 | Golf
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
I need a service manual for an EzGO TXT
Service manuals are sold by EZGO but expensive. You might download some wiring diagrams from fsip.biz and buggiesgonewild.com.
Aug 13, 2015 | EZGO TXT Golf Cart Golf
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
How to troubleshooting sylnoid on 36 volt ezgo golf cart ?
goto buggies gone wild.com there are several forms that share this information on how to check a solenoid. You can also call golf cart kings in Austin Texas. They will tell you exactly how to check the solenoid. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Aug 31, 2014 | Golf
36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
Golf Logo
377 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
