Question about Frigidaire Kitchen Ranges
I have an approximately 4 year old Frigidaire gas stove and I need some assistance with how to relight the pilot light.
Posted by Kellen Ryan on
5 Related Answers
bigg t
anthony james
  • 640 Answers
SOURCE: vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Posted on Nov 17, 2007
gwshaw71
Glen shaw
  • 83 Answers
SOURCE: Kenmore Gas Oven/Stove
the pilot light is under your surface top.Raise surface top and relight.It will be in between both burners.
Posted on Dec 08, 2007
Anonymous
SOURCE: gas meter was changed upon relighting,top burners pilots are on but oven not
under each (the) oven behind a panel, is a red button it may be a different color from time. this has to be pushed and held while the pilot light under the oven floor is lit with a match. it has to be held to allow enough heat to activate the thermocouple, which will keep the pilot on. if this does not work there may be an additional problem
Posted on Jan 23, 2009
Anonymous
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
subdriver
  • 101 Answers
SOURCE: AO Smith water heater about 4 years old pilot went
It sounds like your flame detector (usually a thermocouple) has gotten weak and when you cleaned the pilot the stronger flame was able to generate enough power to keep the gas valve working. If you replace the thermocouple your problem should go away. If a new thermocouple will not keep the gas valve operating...the coil in the gas valve has gone bad and you will need to replace the gas valve assembly. (most valves do not have replaceable coils).
Posted on Sep 10, 2009
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Gas smell when using and not using
follow this steps and fix it. God bless you
f the pilot light on your stove goes out, natural gas may build up in your stove. If your pilot light has gone out, open the kitchen windows and doors for 15 minutes to let the gas dissipate safely then relight the pilot light. Do not relight the pilot light immediately -- striking a match could cause an explosion.
Gas Leak
  • If you can smell the sulfur-like or rotten egg smell of gas, there may be a gas leak inside or outside your home. You might also hear a hissing sound coming from the stove or another appliance or from a pipeline. Outside gas leaks may kill or stunt nearby vegetation. Signs of carbon monoxide poisoning include nausea, dizziness, fatigue and other flu-like symptoms.
f you still smell gas after relighting the pilot light, don't hesitate. Leave your home, along with the rest of your family and pets, then call your utility company or 911 from a safe location. Leave the doors and windows open behind you, especially if the odor is strong or you can hear the hissing of a gas leak. Do not turn appliances or lights on or off or use a phone in your home. Do not strike a match or use a lighter, either. Prevention
Read more: http://www.ehow.com/info_12193884_smell-gas-house-still-lingering-after-shut-off-stove.html#ixzz2aT2VTMtc
Jul 28, 2013 | Maytag MGR5752BDS Stainless Steel Gas...
How do you relight the gas stove.
not knowing the year ,, there are 2 ways stoves light, pilot light and glow plugs, following the gas line into the oven itself, If it has a pilot light you will see the control for it,, just hold a match or flame to the end of it and you should see a button to push,, If you have a glow plug,, it should light after a few second of turning on the knob,, watch to see if there is a glow next to the oven burner if there is and its not lighting,, your thermo coupling may be bad
May 30, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Kitchenaid stove top (17 years old) pilot light is out. How can I relight it?
To relight it you need to pick up the top from the front and then relight the pilot that is in the center between the burners with a match or a lighter...
heatman101
Apr 23, 2011 | KitchenAid Microwave Ovens
How do you light the pilot light on the stove? Model 3627391592
A pilot light will be found on natural gas stoves, fireplaces, clothes dryers, water heaters and furnaces. When the gas is turned off, the pilot light will go out on all of these appliances. After the gas is turned back on, you must relight the pilot light before you can use the appliance. Pilot lights are similar so if you can relight the pilot light for a gas heater you can relight the pilot light for a gas stove or any other gas appliance.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions Things You'll Need:
  • matches OR flashlight
  1. Locate the gas valve by following the gas line in the appliance. The gas valve will have a large red button or knob and will be easy to see and will be well marked.
  2. Check for a gas leak by smelling the area close to the gas valve. Listen carefully for escaping gas and do not attempt to light a pilot light if there is a gas leak.
  3. Hold down or press the red button or knob on the gas valve while holding a lit match in front of the opening in the gas pilot line. Continue to hold down or press the red button or knob for several seconds after the gas ignites to allow the thermocouple (the sensor for the appliance's thermostat) to heat up.
  4. Repeat step 3 if the pilot light goes out after you release the button or knob. In most cases, the pilot light goes out because the thermocouple did not have enough time to heat up, so give it a few more seconds.
  5. Make final adjustment of the gas flow to the pilot light by turning the red knob. In some cases, no adjustment other than "on" or "off" will be needed.
  6. Turn on our appliance to make sure the pilot light ignites the main gas flow. Replace any covers or close any access doors to the gas valve.
Hope this help?
Thanks for using fixya.
Nov 23, 2010 | Kenmore Kitchen Ranges
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Where is the pilot light located
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Dec 15, 2008 | Frigidaire FGB24L2A Gas Single Oven
I have a 1948 Magic chef gas oven.Model # 8620. The gas was turned off at my home and the pilot light on the oven went out. The gas is now on and I need to relight the pilot light. I am not sure on the ove...
You did say 1948, as in 60 year old range?
Well, gas ranges did not have fancy safety valves or things like that back then. Most likely when you turn on the gas, a small amount of gas begins escaping at the pilot orifice. Then use a long handled lighter to put a flame there. Pilot should light right away.
Oct 11, 2008 | Magic Chef Kitchen Ranges
Kitchen Ranges Logo
81 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
