Question about Optics
Model number JTM19T212-TD Serial Number JD8L0900073
SOURCE: Monitor shutting off with blinking standby light.
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Posted on Mar 22, 2007
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at [email protected] if you run into difficulties.
-Dave
Posted on May 12, 2008
SOURCE: Power light blinking red
The tv is NOT in standby mode... it does not have a standby mode !!! But what is happening is.. your tv is getting lamp errors. this can be caused by voltage drops and spikes while the tv is on... and a factory reset can correct this. OR it can be one of two problems.. Bad Power supply or defective lcd panel.
Posted on Dec 18, 2008
SOURCE: TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Posted on Jan 15, 2009
SOURCE: flashing red standby light
Take it down from its mount and try to restart it if this resolves the issue your mount is too tight on the back of the lcd monitor.. This happend to me as well good luck with your BRAVIA
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
Nov 04, 2013 | Televison & Video
Nov 06, 2010 | LG 17LX1R 17 in. HD-Ready LCD Television
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Jun 03, 2009 | LG 42LC42 LCD-TV 42 in. LCD TV/HD Combo
May 05, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Apr 22, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Oct 26, 2008 | Televison & Video
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
183 people viewed this question
