Radio Communications Logo
Posted on Aug 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My headphones work but not my mic i have a hs 2900 and i tried everything its a plug in mic on the left side of my headset i tried some other mics but they dont work either or some are really staticy
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Aug 03, 2009
Anonymous
Expert
Level 2:
Answers
51
Questions
0
Helped
8487
Points
131
See settings / sounds and audio devices
select tab "voices"
check what is displayed in "voice recording"
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
I've just purchased a Genius HS-04SU set - plugged it in to the jacks - nothing, zip zero.. I have tried fixing it from the control panel - no options offered other than realtek input and...
First, excuse my answer/question, but you are plugging mike and phones into correct ports?
I once cursed my headphones & software only to realize that I had foolishly plugged phones into the MIC jack!! :rolleyes:
I haven't seen the jack-plugs on your model, but are they separate, stereo 3-way jack for 'phones and mono 2-way jack for mike?
I'm thinking of a 4-way all-in-one phones/mic jack not matching with stereo 3-way output socket of sound-card.
Working from tip at end of jack-plug,
Mic: Tip=mono signal out, Sleeve=GND
Stereo Phones: Tip=Left in, Ring=Right in, Sleeve=Common GND
Multi: Tip=Left, Ring1=Right, Ring2=Com GND, Sleeve=Mic sig.
Can't hear sounds or use mic
Check your Volume Control and make sure the mic is enabled.
2helpful
Recently bought an Alba HS-820USB headset with mic. Headphones work perfectly but mic is not receording any sound. The headsets didn't come with any software, I think it should be plug and play. Is this a...
just interchange the plugs behind your cpu it must work. and got to controll panell sound devices, advance options click options, properties then change to recording if ur mic vol is mute then uncheck it.
1helpful
Mic is not recognized
i have a GE 98980 headset and window vista wont reconize the mic but the headphones work fine. How do i get the mic to work?
My microphone will not work, and my computer won't recognize!
Common problem with this headset.
In short, the wiring for the mic in the left earpiece is quite shoddy, and over time will be worn away by changing the mic position or come loose with minimal effort.
Have had a over a dozen of these fail in our internet cafe due to this issue after a couple of months use.
2helpful
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
2answers
Creative HS-400 headset & Mic
I had the same problem... with my laptop, using vista. I plugged the mic dirrectly into my laptop and for some miracle, it works! try it out! ^-^
Mic doesn work
same thing happened to me, it wouldn't even work when i went to control panel -> audio devices -> mic test   i think i'm just going to return it for a different model.
headphones worked well though
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
