Model # should be on frame post if you pull out bottom drawer. If not, part # is probably on old part.
SOURCE: Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
SOURCE: How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
SOURCE: I cracked my stove's ceramic glass cook-top
replace the glass. it may be expensive but usually fairly easy
SOURCE: water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
