Question about Maytag Kitchen Ranges
I NEED TO CHANGE THE ORFICE IN THE OVEN FROM NATURAL GAS TO PROPAIN WHERE IS IT AND HOW DO I CHANGE IT??
IT IS A MAYTAG GAS STOVE modle #MGR5750VSQ
Posted by Martha Bryant on
I NEED TO CHANGE THE ORFICE IN THE OVEN FROM NATURAL GAS TO PROPAIN WHERE IS IT LOCATAED AND HOW DO I DO THIS??
To convert this range to LP, you do not need to replace the orifices. The range comes with universal (double coaxial) orifices. You need to convert the pressure regulator; the procedure depends on the range. Then screw down the burner orifice hoods down to the pins. Do not over-tighten or you wil risk damaging the orifice. Then adjust the burner air shutter. For the oven burner, look behind the burner cover. It's shown on as part 25 on the oven/base diagram here: https://www.searspartsdirect.com/model-number/MGR5750BDQ/3048/0124002.html . You can find the range bake and broiler burners shown on the gas controls diagram.
The instructions for converting the Maytag MGR5750BDQ from natural gas to liquid propane (NG to LP) is shown in the installation instructions for the range, starting on page 10. Maytag has the documentation on their support page: . The current link to the manual is https://www.maytag.com/content/dam/global/documents/201103/installation-instructions-8101P404-60.pdf .
I hope this helps.
Maytag neptune gas dryer Model # P MD64000AWW converting to propane and would like to convert back to natural gas
NEED TO CHANGE GAS ORIFICE. THEY ARE DIFF. BETWEEN NATURAL GAS AND PROPAIN THATS ALL YOU HAVE TO DO.
The wall behind my propane oven is black, why?
possibly the air shutters were not adjusted when new for propane use,most units come set-up to burl natural gas but need conversion to burn l.p. gas by changing the orfices on the top burners,then turning the orfice spuds down on the bake and broil orfices as to control the flow of a heavier gas and also opening the air shutters on these venturi gas feed tubes next to these orfices
On my Maytag Gemini MGR6875 the flames on the burners are too high on high and go out on low.
If you haven't changed the stove regulator to natural gas this could be your problem. If you are not comfortable with making this adjustment pleaee check with your gas company or a licensed appliance service person to do the work it should take just a few minutes.
I'm trying to convert a Jandy 250 BTU propaine pool heater to natural gas and I need the parts
go to the pool store or supply house or call the manufacture if anyone there speaks good english. and tell them what you got and that you need the propane orfices and the propane gas valve and regulator for your pool heater. you'll need to change the orfices, gas valve and regulator.
1helpful
2answers
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
1helpful
Can fix Gas leak smell in GE Eterna stove: Model EGR3000EH1BB
If it was used with LP and you are using it with natural, did you change everthing back over to natural gas settings? Orfices, regulator cap, and oven orfice?
It could be a pressure issue.
Vic
8helpful
3answers
How do you adjust flow regulator in gas oven
how do I adjust my regulator on a gas range
3helpful
3answers
Dean deep fryer
need to change from natural to propain sr42 g
Kitchen Ranges Logo
Top Maytag Kitchen Ranges Experts
Vernon Taylor
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
