IT IS A MAYTAG MODLE #MGR5750BDQ
To convert this range to LP, you do not need to replace the orifices. The range comes with universal (double coaxial) orifices. You need to convert the pressure regulator; the procedure depends on the range. Then screw down the burner orifice hoods down to the pins. Do not over-tighten or you wil risk damaging the orifice. Then adjust the burner air shutter. For the oven burner, look behind the burner cover. It's shown on as part 25 on the oven/base diagram here: https://www.searspartsdirect.com/model-number/MGR5750BDQ/3048/0124002.html . You can find the range bake and broiler burners shown on the gas controls diagram.
The instructions for converting the Maytag MGR5750BDQ from natural gas to liquid propane (NG to LP) is shown in the installation instructions for the range, starting on page 10. Maytag has the documentation on their support page: . The current link to the manual is https://www.maytag.com/content/dam/global/documents/201103/installation-instructions-8101P404-60.pdf .
I hope this helps.
SOURCE: conversion help
you need to unscrew the orifice until the flame stops yellow tipping meaning you have very little yellow at the tip of the flame
SOURCE: How do we get to
depends on dryer the orifce is on the end gas valve inside dryer best to have it done by propaine man
SOURCE: injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
SOURCE: Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
