Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
When initially turned on TV will alternat between picutre & black
This is a Sony 34" Trintron that I purcahsed new 17 yrs ago. This problem just started happening over the weekend. When the TV is inititially turned on, the TV will alternate between showing the picture and sound and then flashing to a black screen. After a minute or so, the TV picture remains on.
Posted by ericfreund01 on
  • ericfreund01 Aug 03, 2009
    The sound remains on but I dont hear any other noises when the screen goes black.
jrweighing
    Novelist:
  • 183 Answers
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Posted on Aug 03, 2009
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
Jul 30, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My sony trintron 21" bottom
RE-SOLDER VERTICAL SECTION & CHECK IT.ALSO CHECK PIN CUSHION SECTION.
Jul 29, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Battery & brake light came on at same time. new battery & rebuilt alternater 2 yrs ago.
check the charging rate the alternator is producing, if the performance is insufficient, it can cause other warning lights to come on as the system does not have sufficient power to run their self diagnostics within their operating parameters.
Dec 04, 2009 | 2001 Isuzu Rodeo
Fd trintron won't turn on standby flashes 6 times I have done a hard reset and it worked for a couple of times and is gone again
There are some IC's in the power supply that are going bad. This is a pretty complicated repair. You may want to have a repair shop check it out for you. Thanks
Nov 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I want lock code for sony ericson k660i
First download this software: Ultimate Unlocker v1.01 by Cruiser Team(search google its free!)
Follow the example given below:
Successfully unlock K660i (A2) 17:25:25 Ultimate Unlocker v1.01 by Cruiser Team 17:25:26 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:25:26 Initializing... ! 17:25:26 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:25:26 2. Choose the phone model ! 17:25:26 3. Select the desired options ! 17:25:26 4. Please connect the phone either via USB while holding 2-5… ! 17:25:26 - or via a serial cable and double-click on it in the device list 17:25:34 Connecting via Generic EMP USB Flash Device (USB1)… 17:25:34 Device driver version: 1.1.0.12 17:25:34 Device driver date: 9-25-2006 17:25:35 Connecting to the baseband CPU... 17:25:35 Entering baseband CPU service mode... 17:25:35 Detected chipset: DB3150 17:25:35 Boot mode: ROM 17:25:36 Sending loader... 17:25:37 IMEI: xxxxxxxxxxxxxxx 17:25:37 OTP CID: 52 17:25:37 Product type: Retail 17:25:37 Effective color: Red 17:25:39 Sending loader... 17:25:40 Communicating with server… 17:25:44 Remainig credit (supreme): 1.00 17:25:49 Remainig credit (supreme): 1.00 17:25:49 Converting phone to blue… 17:25:49 Please reconnect the phone (disconnect, connect while holding 2-5) 17:26:01 Sending loader... 17:26:02 IMEI: xxxxxxxxxxxxxxx 17:26:02 OTP CID: 52 17:26:02 Product type: Retail 17:26:02 Effective color: Blue 17:26:04 Sending loader... 17:26:08 Code NCK for relock: 9753585490502778 17:26:08 Code NSCK for relock: 3889412532359257 17:26:08 Code SPCK for relock: 3171907565654182 17:26:08 Code CCK for relock: 6478061648618760 17:26:08 Code PCK for relock: 3949070691496765 17:26:08 Code ESLCK for relock: 9101944641118096 17:26:08 Code NCK for unlock: 9012406338647640 17:26:08 Code NSCK for unlock: 2040670855123632 17:26:08 Code SPCK for unlock: 0923191541634191 17:26:08 Code CCK for unlock: 4556970785063717 17:26:08 Code PCK for unlock: 1754665636774190 17:26:08 Code ESLCK for unlock: 2257853277910517 17:26:08 To enter a code, type < * * < on the phone with SIM-card inserted 17:26:09 Turning off the phone... 17:26:11 Done. ! 17:26:11 Please disconnect battery and cable from the phone!
Alternatively you can do this:
hard reset *2767*3855# (this erases all ur data, you can preserve ur data by takin a backup.)
Aug 23, 2009 | Sony Ericsson P1i
Unlock code k660i on 3 network
17:26:11 Done.
Aug 22, 2009 | Sony Ericsson K660i Cellular Phone
I have a Sony Trintron also - similar model to the
looks like a horiz.output transistor is shorted.check it...
Jul 08, 2009 | Sony KV-32S45 32" TV
Sony Trintron Model # KV-27S22 Flashing screen
Hello
I got it fixed today at the TV repair shop down the street.
Thanks
Nov 11, 2008 | Sony HT-DDW840 System
Sony wega trintron wont turn on
Most likely there is a failure in the power supply or in the scan amp sections. This will require factory level troubleshooting to determine where the faults are.
This type of service may be on the expensive side.
Jerry G.
Oct 21, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
160 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
