Question about Manitowoc Kitchen Appliances - Others
Harvest light continuously blinks on my manitowoc ice machine
Posted by Steve Walker on
My Manitowoc Ice machine will not produce ice. The harvest light is on and it will run through the clean cycle
Hi, contact your local appliance repair facility, you may have problems with the control board, the ice level sensors or curtain.
Nov 26, 2017 | Manitowoc Kitchen Appliances - Others
I HAVE A MANITOWOC QM30A ICE MACHINE. WILL THE LIQUID LINE THERMISTOR CAUSE IT TO RUN BUT NOT MAKE ICE?
Liquid line sensor on ice machines in general is used in conjunction with the control boards to determine defrost and harvest cycles. You could measure the line temp and chech the resistance of the sensor to check it.
Betabass
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jerry_8a145f1328fa119f
Sep 07, 2016 | Manitowoc QM30A Self Contained 65Lb...
How can i fix my manitowoc qm45a runs water but won't freeze the water?
The thickness sensor is shorting, making the machine continually harvest. Clean it and dry it. If it still happens, replace the sensor.
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
It will not stay in harvest cycle long enough to make ice before it goes into defrost
First it has to go through freeze cycle then harvest cycle to drop ice then back to freeze cycle. If you have never worked on ice machines before you should call a service company.
Aug 16, 2013 | Manitowoc QY-0214A Self Contained Ice...
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
All cycles work except harvest manitowac ice machine
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Harvest light on Manitowoc Q series stays on
obtain wiring diagram
sounds like the switch that initiates the harvest is stuck closed....sounds funny but i would try to tap the unit and see if the light goes out
Oct 01, 2009 | Manitowoc Koolaire Undercounter Freezer...
Kitchen Appliances - Others Logo
610 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
Marvin
Marvin
Dennis
john h
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
