Question about Mercury Boating
My mercury 500 thunderbolt 50 hp will not spit water? I also am having problems with it running. It cuts out when put into gear or after about 10 seconds. What should I do?
Posted by Tanner Brockman on
Whats the firing order on a mercury 500 thunderbolt marine engine ?
Remove the 4 spark plugs , number 1 is the top piston so put it to tdc then with a screw driver feel through each plug hole for which is the next piston to come up to tdc etc etc till you have written the order ! 1,2,4,3 or 1,3,4,2 !!
Oct 14, 2014 | Clymer Mercury/mariner 75-275 Hp...
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
I have mercury 50 hp 4 stroke thunderbolt serial no 2307966 any information
www.mercurymarine.com/parts-and.../parts-catalog
4 stroke cycle? More likely two stroke cycle with oil injection.
Jun 13, 2014 | Computers & Internet
I need the type and info on my Mercury Classic 50 outboard motor
serial number is what you need and try looking on the starter or the switch box ( square box with lots of wires on as they have dates on also ) take pictures of engine in and outside as if decals are original it will date it as well ! take to or email your nearest dealer with all info and they date your engine no problem !
Mar 20, 2014 | Boating
Mercury 850 Thunderbolt outboard
call mercury don't think they had a place for water pressure hose in the 70s on there motor
Aug 30, 2013 | Boating
85 hp force eng stops running when put into gear and then given more throttle(only hapens in the water)ok out carbs rebilt ,filters cleaned
check compressions 100psi or more on all cyls ! carbs balanced ? sparks on all cyls ? crank seals could be worn ! tick over 1000rpm then in gear 800rpm ish ! In water !
Oct 29, 2012 | Seloc Mercury Outboard Engine Repair...
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
275 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
