Question about Cuisinart (ICE-20) 1.5 Quart Ice Cream Maker
Sorbet not freezing
I followed directions exactly for the lemon sorbet-did not freeze so I put liquid in fridge overnight separate and re-froze bowel making sure my freezer was set cold enough. It is still not freezing.
Posted by bonniefell on
A Miller
  • Cuisinart Master
  • 8,404 Answers
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Posted on Sep 07, 2009
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
Hi. Have just bought one at a second hand shop and tried to make the Lemon Sorbet. Ing: 300ml lemon juice, 100g sugar, 1egg white and water. HOW MUCH WATER Please.
Lemon Sherbet Ingredients
  • 2 egg whites
  • 3 - 4 cups (500-750 ml) lemonade
  • sweeten to taste
Instructions Beat egg white until foamy but not dry. Mix in lemonade and sweetener and pour into Donvier. Freeze to desired consistency.
Mar 06, 2011 | Donvier Ice Cream Maker 1 Quart
How do you use a cuisinart frozen yogurt ice cream & sorbet maker
look on line; lots of manuals and recipes available. I'd say yours is one where you freeze the bowl over not and refrigerate the mix overnight too. You can buy the mix, but much more fun to make you own. I'd be borrowing a book from the library so you can experiment, but generally its make a 4 egg custard + 6 tblspn caster suger + 300 ml cream + flavour eg vanilla. I use powder custard + twice as much sugar to make custard and it works too! have fun
Jul 30, 2010 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Lumina (Aldi) ice cream maker instructions
Before using the first time:
1. Remove all of the packaging.
2. Wash the parts. (the paddle & the bowl only)
3. Eight hours in advance, place the inner bowl into a freezer.
4. Prepare the ice cream or sorbet mix (see recipe ideas)
Allow the mix to cool in the refrigerator.
FYI, I freeze the inner bowl overnight instead of the eight hours as stated in the manual.
Dec 29, 2009 | Ice Cream Makers
I have the machine but not the manual that goes with it.
Things You'll Need:
  • Fruit
  • Blender
  • Vodka
  • Lemon juice
  • Sugar, honey or agave nectar
  • Ice cream maker or freezer
  1. Choose your fruit or even blend more than one kind of fruit. As a general rule, it is best to use juicy, pulpy fruit, such as watermelon, mango or strawberries; however, you can add a splash of orange juice or even throw in banana for extra cream. Blend your selected fruits well in a blender.
  2. For every 2 or 3 cups of blended fruit, add 1 Tbsp. of vodka and 2 Tbsp. of lemon juice. If you are serving sorbet to children or cannot consume even these small amounts of vodka, simply replace with lemon juice; however, know that you will not be able to taste or feel the effects of vodka in your finished product.
  3. Blend sugar into the mix; however, add just a spoonful at a time, tasting until you reach your desired level of sweetness. As an alternative to sugar, you can use honey or even agave nectar.
  4. Place your mixed sorbet in an ice cream maker to freeze for the creamiest results. If you do not have an ice cream maker, simply place your sorbet in the freezer for a few hours; however, sorbet will be a bit harder in texture but just as tasty if frozen in the freezer.
Aug 23, 2009 | Musso Lussino Dessert Maker 4080 1.5 Quart...
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
First use - it didn't freeze
Try lowering the temperature of your freezer a few degrees. I had the same problem and this solved it.
May 10, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Its not working!
Here is the link to the manual if you need it; http://www.cuisinart.com/share/man/423_man.pdf It sounds to me like everything should work, but you put something in the ingredients which affected the result - salty or hard or softened water might be a problem - also insufficient rinsing of any detergent you might have used. try different ingredients. Also get a thermometer and check the temperature of your freezer - the problem may be that the freezer is only hitting a couple of degrees below zero celcius. about -8c or more should be enough for your ice cream maker, more is better for your frozen food check your freezer manual for details - please post again if you need this. Hope this helps :)
Aug 10, 2006 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Cuisinart (ICE-20) 1.5 Quart Ice Cream Maker Logo
621 people viewed this question
Top Cuisinart Ice Cream Makers Experts
ThaMp3Doctor
ThaMp3Doctor
Not Me
Not Me
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
