Question about Necchi Sewing Machines
Adjust thread tension on necchi model 4575 sewing machine
Posted by Aurora Chavez on
5 Related Answers
Anonymous
SOURCE: Necchi 4575
I've found that my machine doesn't like Coats & Clark thread; I have to feed it Guterman
Posted on Aug 04, 2008
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Posted on Apr 26, 2009
paj42
  • 1116 Answers
SOURCE: necchi 511..how do you adjust thread tension on
Before the thread goes though the uptake lever, it goes though the tension (a round "knob" with numbers).
When threading the machine, lift the presser foot. This opens the tension control so the thread can enter and then when the foot is down and you begin to sew, the tension setting will determine how much thread should feed to the needle.
The setting is usually around 4. However, if this is an older machine that has been used a lot and serviced a little, the tension may not work as it should.
Try different settings and if you cannot get a proper stitch, you will need to determine if the machine should be serviced or if you should purchase a new one - service and parts can be 1/2 the price of a decent, new machine.
Posted on Feb 28, 2010
Testimonial: "Machine is now sewing properly. Thank you."
paj42
  • 1116 Answers
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
Posted on Mar 06, 2010
paj42
  • 1116 Answers
SOURCE: How to adjust the bobbin tension?
On a sewing machine, the first "knob" in the threading process is usually the tension.
Try threading the machine with the presser foot up, first. Sew a few stitches and then make adjustments as needed - right is a tighter and left is looser when turning the tension adjustment.
I would recommend buying sewing machine. These little gadgets are cute, but they just don't do that well and are not worth the stress they create.
Posted on Mar 18, 2010
Necchi nova
uneven thread tension between upper and lower thread.
Sep 09, 2014 | Necchi 4575 Mechanical Sewing Machine
How to thread 4575
From the reel on top, thread goes to the left and over the back guide and then to the front, straight down through the tension disc make sure the presser foot is up so the discs are open,round the first guide and back up to the takeup lever making sure thge lever is at the top, through the takeup lever right to left, straight down towards the needle taking in any cotton guides on the way and thread the needle front to back
Oct 02, 2013 | Necchi 4575 Mechanical Sewing Machine
Machine is skipping stitches no matter what tension is used.
try these things
1.needle inserted into holder wrong
2.needle may be bent
3.wrong needle in machine
4.size of needle & thread not compatible
Aug 04, 2010 | Necchi 4575 Mechanical Sewing Machine
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Mar 14, 2010 | Necchi 4595 Mechanical Sewing Machine
Thread is balling up in the bobbin area
Top tension about 4 or 5 makse sure you have the bobbin in the correct way round and make sure you can just pull the thread through with slight resistence.
Mar 06, 2010 | Necchi 4575 Mechanical Sewing Machine
Necchi 4575
Feb 06, 2008 | Necchi 4575 Mechanical Sewing Machine
Sewing Machines Logo
83 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
