Question about Samsung Office Equipment & Supplies
How Do I Open Samsung Xpress M2070w printer machine to Remove Paperjam
Posted by Golam Mostofa on
Jessica Michael
    Master:
  • Samsung Master
  • 459 Answers
1, Paper jams occur when papers are stuck inside the laser printer. It affects the entire printing process. Lift the scanner unit and open the jam cover. Raise the fuser dummy cover. Discard the jammed paper by pulling it outwards gently. Close the fuser dummy cover and the jam cover.
2, Lower the scanner unit. Open the middle cover and take the toner cartridge from its slot. Remove the jammed papers and reinstall the toner cartridge. Close the middle cover and the scanner unit.
3, If the paper jam error still occurs, look for paper jams in the input tray area and remove them.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
Posted on Oct 16, 2018
How do i sort out my jammed paper for my samsung multifunction xpress laser printer m2070w please
pull out the toner cartridges and see if paper wedged under the cartridges. Pull out the drum unit see if paper wedged under it.
Check back of printer . may may a cover where paper turns around may be jammed in this location also. check paper tray pull it out see if paper jammed at paper pickup point.
Check printer user manual for clues on how to clear paper jams
page 91
http://downloadcenter.samsung.com/content/UM/201512/20151210113455258/EN/english.pdf
Jul 03, 2016 | Samsung Office Equipment & Supplies
Hi, pull out the toner and check if there's any paper sit in the path? Otherwise, you need to remove the front cover, both side cover then the back cover.
Feb 09, 2015 | Samsung Office Equipment & Supplies
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Paperjam 2 message is comming
hello ,
their is a paper jam inside backside in a machine open the backside and check it
Aug 16, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam - where do I get instructions on how to fix?
To remove the paperjam in machine you need to:
Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well. Remove the paper tray there could be a piece of paper stuck there.
Wherever you find the Jam remove it slowly so it doesnt rip.
Jun 24, 2010 | Brother HL 2140 Laser Printer
My canon mp190 gives E3 paperjam error but there is no paperjam how do i fix it?
I have solved this problem with read post at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html thanks to slayo.com "Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things." you must open your printer to remove the things, maybe waste letter or other small part things. Read the post for complete it.
May 18, 2010 | Office Equipment & Supplies
Hiya my brother dcp 7010 printer keeps saying back cover open please shut cover but there is no cover open how can i fix it pls
This is happening because there is a paperjam in the machine and its covering the sensor for the back cover. Open the front cover of the machine and remove the drum and toner, then you can remove the paperjam.
May 06, 2010 | Brother DCP 7010 Multifunction Laser...
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
504 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
