Televison & Video Logo
Darrin Suttles Posted on Oct 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a 32 inch Onn tv and I am trying to connect to hdmi for my computer
JC Meredith
Level 2:
Sergeant:
  • Expert 168 Answers
  • Posted on Oct 05, 2018
JC Meredith
Expert
Level 2:
Sergeant:
Answers
168
Questions
Helped
42850
Points
741
resolution has to match the tv and the computer or youll have a black screen. keep switching resolutions in display properties in computer untill it submits 480 /720/1080
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Jul 31, 2007
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
A
Anonymous
  • Posted on Apr 12, 2008
SOURCE: ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Anonymous
  • 208 Answers
  • Posted on Sep 28, 2008
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Anonymous
  • 9 Answers
  • Posted on Jan 16, 2009
SOURCE: 32 in Astar LCD won't recognize input signal
Hello, According what you saying not recognize any iput. Then your main board is defective.
The HDMI and the YPbPr are the same connection according the main board build. Any other question please call 323-767-6030.
fixyathing
jhun T
  • 341 Answers
  • Posted on Aug 16, 2009
SOURCE: i have an onn 32 inch lcd tv that will not turn on
Most probably a switching power supply problem. Have it checked by a qualified technician.
Samsung Galaxy A14 phone. Trying to connect my phone to my Philips tv model 32PFL5322D. I bought an HDMI cord, connected my phone into tv but got nothing. Now what?
Question edited for clarity and what I think you thought you were saying, except for 'Tv is oler'. Older or OLED?
You don't say WHY you want to connect your phone to your television. This television is VERY basic. The HDMI Ports will be looking for a DVD or Video tape player AV data signal, not a phone.
https://www.usa.philips.com/c-p/32PFL5322D_37/81-cm-32-inch-lcd-integrated-digital
Philips 32PFL5322D/37 Manuals
ManualsLib https://www.manualslib.com > ... > LCD TV
PHILIPS 32PFL5322D/37 Manuals. Manuals and User Guides for PHILIPS 32PFL5322D/37. We have 4 PHILIPS 32PFL5322D/37 manuals available for free PDF download: User ...
Bytecc 4K2K LPCM 7.1 Extractor
It appears that the Bytecc 4K2K LPCM 7.1 Extractor may not be fully compatible with the ARC (Audio Return Channel) feature on your ONN Roku 40 TV. Here are a few suggestions to potentially solve the issue:
1. Ensure that both your TV and the Bytecc 4K2K LPCM 7.1 Extractor support the ARC feature. Check the user manual for the specific HDMI port on your TV that supports ARC, as not all HDMI ports may have this feature.
2. Double-check your TV audio settings. Make sure the audio output is set to HDMI ARC, and if there's a setting for audio format, choose LPCM.
3. Try using a high-speed HDMI cable that supports Ethernet, as the ARC feature requires this type of cable.
4. Perform a factory reset on your Extractor and reconnect it to the HDMI ARC port on your TV.
2answers
I can’t get my universal remote to take my on TV ONN off photo
Universal Remotes don't work with Photo Frames. Televisions, DVD and Cable Boxes only.
Or
Try this: with the TV OFF, hold down the MENU button on the side of the TV, and while holding it down, turn On the TV. That may get it out of photo display mode, if it is a typical ONN TV.Dec 26, 2018
It's on photo mode. Not old and it's a onn tv and 32 inch the ...
https://www.justanswer.com/tv-repair/bvozn-it-s-photo-mode-not-old-it-s-onn-tv-32-inch.html#:~:text=Try%20this%3A%20with%20the%20TV,is%20a%20typical%20ONN%20TV.
I just bought a Onn 32 inch tv and cant seem to connect to hdmi for my pc
provided you have the hdmi cable connected to both devices it should just be a case of configuring the computer for it.
please read this wiki for tips on doing so
How to Hook Up Laptop to TV
32" onn tv hdmi is
Hi:
The best way to repair this problem is to replace the main signal board. The HDMI connections on the board may of come loose but replacing the board is the best solution at this point.
2answers
I have a Proscan 40 inch 1080P LCDTV (40LD45Q), but when I connect my computer to it, (GTX 260) with DVI-HDMI cable, it says the native resolution is 1366x768. Is Proscan lying that this TV is 1080P?
You can attempt to force 1080p to the TV by unchecking the box "hide modes this monitor cannot display" in the display adapter propteries, then try to select 1920 by 1080p, 60hz, 32 bit color, and see what happens. Post back what your findings are.
2answers
How to use rca entertainment series 32 inch as pc monitor
Assuming that your RCA 32 inch tv has an HDMI or VGA input, all you need is the proper cable to connect the two units. If your computer has a VGA out (blue female connector) and so does your TV, you would need a male to male VGA cable. If your computer has a DVI out (white connector), you would need to purchase a DVI to HDMI cable. The combinations can me played around with depending on what connectors are on the back of the TV and what you have as an output for your PC.
2answers
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
3helpful
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
