Question about Nortel Lands Phones
We have one phone line. Can we conference with nortel 7316E?
Our church has only 1 phone line and someone donated some Nortel 7316E phones. Can we conference call on it even though we only have one line
Cabanaboyz
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 122 Answers
You can conference people WITHIN the system. If you want to do it with 1 line and externally, you have to do that through your carrier like AT&T
Posted on Dec 29, 2018
5 Related Answers
Anonymous
SOURCE: how can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
Posted on Jun 11, 2008
Anonymous
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
Anonymous
SOURCE: change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Posted on Jun 16, 2009
Anonymous
SOURCE: changing name in nortel T7316E handset
We would like to change the name displays on our phones
Posted on Oct 22, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Posted on Oct 27, 2009
Testimonial: "This posting saved us $110 service call! Thank you! Thank you!!"
How to disable the speaker on the phone
On most older nortel systems you can use the feature,*,6 buttons to adjust the ringer type, along with type you can set the volume by using the up/down volume buttons.
Jun 21, 2013 | Nortel refurbished 7316e phone
How to find my mac address for nortel t7316e
A T-7316e not having an internet CAT5 connection does not have a MAC address.
Mar 31, 2013 | Nortel Networks Business Series Terminal...
Can I change the ring tone for just one of the lines on my nortel norstar phone m7324?
If your phone system has 6.1 software or up then yes,the tech or vendor can program it for you. If you know how to program look under Config/Lines for Ring Type.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
I have Nortel Polycom 2033 IP conference unit. When we have a conference, it's really bad sound quality. Is there anything that i can do? Thanks.
has it always been like that or it just started. this can be a speaker gone bad or an unstable line. a simple service may correct that effectively.
Jul 27, 2011 | Nortel Audio Conference Phone 2033...
Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Dec 07, 2009 | Nortel Norstar 16-Line PBX Speakerphone
How to get voicemail from another phone nortel 7316e I am trying to get my office messaged from my cell.
If your trying to get your messages from another nortel set in the office press your open voicemail button or feature 981. The left soft key below the screen should say OTHR. press the soft key the screen should change to LOG: enter in the mailbox number followed by the password and #.
If your trying to get your messages remotely, call into the office and when the auto attendant answers, press ** followed by your mailbox number password and #.
Nov 02, 2009 | Nortel T7316E 2-Line Corded Phone
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
How do I do conference calling?
With caller on phone, press the conference button. You will get intercom dial tone. DIal another extension or grab a line and dial another cell number. When connected, press "conference" again, and you will all be together.
Jun 24, 2009 | Nortel T7316E 2-Line Corded Phone
Lands Phones Logo
Top Nortel Lands Phones Experts
Marvin
Marvin
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
