Question about Jet Health & Beauty
Jet 3 ultra wont turn on.
I had the scooter all charged up turned it on and moved it, shut it off and now it will not turn back on. All connections are tight. Is it my batteries because when I plug it in the ammeter jumps up then drops right down to zero
Posted by Donald Estes on
Marvin
    Top Expert:
  • Jet Master
  • 85,239 Answers
Yes the batteries are defective.
Posted on Oct 04, 2018
3 Related Answers
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
Anonymous
  • 14 Answers
SOURCE: When I plug in my jet 3 ultra the ammeter reads 0.
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Posted on Mar 07, 2010
Anonymous
  • 6 Answers
SOURCE: need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
Posted on May 12, 2010
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
Why does the Victory 4 scooter not move. It worked fine for 20 minutes. I shut it off, then when I tried to ride again it would not go. No sounds. Battery is charged and light and horn works.
hi, there can be a number of reasons for this, from a controller fault to a weak pair of batteries to a brake that is breaking down..
Please contact me so i can advise further...
Regards
Rob
www.gewizrepairs.co.uk
Jul 06, 2014 | Pride Electric Wheelchair, Scooter, Power...
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
May 25, 2012 | Jet 3 Ultra Power Chair
I own a Pride Go Go four wheeled scooter. When scooter is turned on, even though batteries are fully charged, the scooter will not move. I have found that if i then switch it off and switch it from being...
Problem seems to be in the brake wiring or micro switch on the brake itself that is causing your problem check the brake and wiring to make sure you have good connections and check if you can see that the micro switch is working correctly. try leaving the switch on and moving the freewheel lever to see if it will reset without turning the switch off if it doesn't and you have to turn it on then off then there is a problem in the brake circuitry signal to the console and you will have to replace the brake/microswitch assembly. Hope this helps
Feb 28, 2011 | Pride Mobility Products Health & Beauty
Health & Beauty Logo
54 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
