Question about The Watches
Removing back cover on Stauer Atomic New York to Paris watch. There isn't enough groove on the back for a verrry small jewlers screw driver, or a knife blade, Emergency room,to even pop it off. Mike
Posted by Mike Baehm on
Bill Boyd
    Top Expert:
  • The Master
  • 53,816 Answers
Requires a special knife edged clamp for the job
probably a water proof watch that requires specialist equipment to break the seal
Posted on Oct 04, 2018
4 Related Answers
David Tolond
  • 2501 Answers
SOURCE: I want to send my atomic stauer watch for repair.
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
Posted on Mar 20, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Posted on Apr 08, 2010
Anonymous
  • 714 Answers
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on May 14, 2010
Geoff
  • 125 Answers
SOURCE: my stauer atomic signal watch won't set correct time
Take a look at http://www.stauer.com/pdf/17468.pdf
I see that this watch gets it's time signal from Boulder, Colorado so it will only work properly in North America. Perhaps they also do models for the European market - if so I would expect them to work in the same fashion so the manual should still be relevant.
Posted on Aug 01, 2010
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
How do you reset the time after changing the battery in a stauer 11475 atomic watch??
Jul 29, 2010 | Casio Wave Ceptor WVA430A-1AV Wrist Watch
Battery replacement
do you mean you want to replace the battery for your watch?
This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
Good luck.
May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
I want to send my atomic stauer watch for repair. Could not set watch when newly received. Where do I send Stauer watch for repair?
GOTO:
r/ David
May 12, 2010 | Fossil Watch
Apr 08, 2010 | Swiss Stauer Deep Dive Watch
Mar 20, 2010 | Bulova Watch
How to set the time on a stauer atomic watch
i have a stauer 33 watch i can not get the pin to come out so i can set the date and time it is like it is stuck or am i not doing it wright. thanks for your help
Oct 21, 2009 | Bulova Watch
My stauer atomic signal watch won't set correct time
Aug 08, 2009 | Bulova Watch
I have a watch i need to take links out
I have a similar watch band and the little grooves are really not for screwdrivers. It is a split pin that just pushes out. I use a jewler's screwdriver or a small nail to push them out because I don't have a pin punch that size. Hope that helps.
Mar 14, 2009 | Watches
How do i change the battery in a timex wr 30 m watch
remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
Dec 31, 2008 | Timex 27191 Wristwatch
Watches Logo
181 people viewed this question
Top The Watches Experts
John mullen
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Watch Expert? Answer questions, earn points and help others
