She was adopted by her stepfather when she was 10 on the birth certificate she lost her last name was her stepfathers does she use his information when filling out the for for a new birth certificate
Hello, Theresa -
Your daughter will use her step-father's surname / her last name after her adoption when applying for a replacement birth certificate.
You answered your question with this statement in your post: ". . . on the birth certificate she lost her last name was her stepfathers"
Best wishes.
SOURCE: Inside refrigerator is warm - but freezer seems to be working.
friend .
you need to have check of your condenser.
either the condenser has gone down.so the gas is not there to cool.
see that u can hear the sound of motor running.if it works.
i am sure the cooling problem may be due to this.
SOURCE: My stepfather fixed the exhaust (P0171/P0174) and
Hello, You will still get a light for about 35 Startups unless you wipe the memory. You can get a free scanner wipe at Autozone, Oreillys, or Advance autoparts. Another way is to disconnect the NEG battery cable for 10 minutes and it should reset.
SOURCE: Presently I'm using the name
easiest way is to have your name changed in your birth certificate as it is easier to update just 1 document rather than changing all those other documents that you have..you have to contact your local registry office
