Question about Blaupunkt Car Audio & Video
I have the code, removed the fuse from my blaupunkt cd51 but I can't find a way to enter the code,after 10min I start the car and the radio starts playing and beeping, suggestions?
5 Related Answers
Anonymous
SOURCE: PIN Code for BLAUPUNKT SEVILLA CD51
how do you input the code for this
Posted on Nov 18, 2008
xxxxxx xxx
  • 5023 Answers
SOURCE: My Blaupunkt, Heidelberg CD51 car stereo beeps
That normally means that it requires the  security code to be entered.
Disconnect the fuse for 10 minutes, replace then enter the code.
If you do not have the code then the radio will have to be removed from the dashboard and quote all the letters+numbers on any labels, barcodes or stamped in the metal casing.
Also quote the make of car it is fitted into.
Posted on Sep 02, 2009
xxxxxx xxx
  • 5023 Answers
SOURCE: Blaupunkt RDS car radio code needed
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here  for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
There should be a 14 character number beginning with
BP++++++++++++ and also a model number beginning with
7 *** *** *** so quote everything you can find
Also quote the MAKE of CAR
Posted on Nov 03, 2009
xxxxxx xxx
  • 5023 Answers
SOURCE: Citroen/Blaupunkt radio unlocked but won't stop beeping
VIN coded radio.
Radio will require coding to your car`s management+security system.
Contact your Citroen Dealer or Radio Decoding Business
Posted on May 29, 2010
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: How do I enter the code I'm my blaupunkt car radio
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Posted on Apr 05, 2013
How to input code into a blaupunkt radio
afaik you need to turn the radio on
and leave it on till the display start to flash code
then you can enter it
these code radio and a pain i would remove the nvram and bypass the need for a code
its a pain in the rear everytime the battery is dis or etc.. its a hasle
with a £10 to remove it completely
Dec 04, 2014 | Cars & Trucks
Won't eject CD
well the owner manual says to press button 9 and then flip down the face of the radio and it eject the cd. not just flip the face down . here is a link to the eject instructions..how to eject the cd on a miami beach cd51 have more questions email me at [email protected]
Oct 28, 2013 | Blaupunkt Miami Beach CD51 CD Player
Apr 04, 2013 | Car Audio & Video
Need rear panel drawing or install instr for Heidelberg CD51
Crutchfield has the manual available for download here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/023/023HDLCD51.PDF
I saw a picture in the manual showing where the various connectors plug in. You should be able to tell from there what the orientation should be. It was page 29 of the PDF.
Feb 16, 2010 | Blaupunkt Heidelberg CD51 CD Player
What is Blaukpunkt Casablanca CD51 car radio serial number.
It should be engraved into the side of the radio, if not you will need to remove it and take it to a decoding specialist.
Nov 28, 2009 | Lands Phones
How do I enter the radio pin code (which I have) for a 2001 Holden Vectra JS Series? The radio is a BLAUPUNKT factory standard model.
press and hold AS button for a couple of seconds till beep is heard and CODE----
is displayed in the display
use the preset button 1to get 1st number then preset button 2 to get second number etc.... until all 4 digits are entered then press and hold AS button again until beep and radio should start working
Oct 31, 2009 | Blaupunkt Car Audio & Video
My Blaupunkt, Heidelberg CD51 car stereo beeps every minute or so, whether you're listening to the radio or CD's? - HELP please
Aug 31, 2009 | Blaupunkt Heidelberg CD51 CD Player
How do I enter code into my blaupunkt radio/cassette?
HY ACORDING TO THE MANUAL YOU SHOULD TURN THE IGNITION ON SWITHCH THE RADIO OFF PRESS THE AS BUTTON WHILE YOU TURN THE RADIO ON,AFTER 5 SECONDS YOU SHOULD HER A BEEP AND ON DISPLAY YOU CAN SEE 10SAFE AFTER 5 MORE SECONDS YOU SHOULD BE ABLE TO ENTER YOUR CODE USING FIRST FOUR BUTTONS FOR 0-YOU PRESS ONCE AND SO ON WITH THE OTHER DIGITS.
Jan 30, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Sheldon Dedek
Tom Chichester
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
