SOURCE: SAMSUNG BLUETOOTH PAIRING
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (Serched bluetooth device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
SOURCE: Samsung F480 mobile bluetooth connection problems
two sybols on phone: Bluetooth and another with device name that it is trying to connect to. Drag the device name symbol onto the bluetooth symbol. will ask for password, then it will connect. there will be a dotted blue line now to the device it is connected to
SOURCE: samsung b2100 turns it self off and on again bluetooth
hi
I have had the same problem with my Samsung B2100 but the thing is i have sent the phone back 4 times now because it turns it's self off and back on again when it is connect to bluetooth.
When i take it back they look at me if i am the only one in the world that has this problem.
Can any one help me?
SOURCE: I have a Vauxhall Insignia SE which comes with all
Halfords Parrot kits integrate into the system all beit the steering wheel controls dont work. The audio is muted for incoming calls and the car speakers are utilised. Works well.
