Question about Panasonic Car Audio & Video
I have a Panasonic 6 disc cd chnger when i try to play it it displays 1E2 error whts the problem
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: cd error message
Try to disconnect battery contacts and connect it back. Check also if there is an emergency opening device. In some model you have a pin hole underneath the cd tray. push a staple tip inside the hole, and this will release the cd.
If the tray still does not open, you may need to have a repairman opening your stereo at your local service point.
Regards
Posted on Apr 03, 2008
Anonymous
  • 28 Answers
SOURCE: 2002 F250 4X4 Supercab CD player stuck
Cd mechanism issue, may be a broken gear.
It would not be able to read discs or load them, or throw them out.
Posted on Aug 14, 2008
Anonymous
SOURCE: My panasonic SA-AK750 hi fi
Hi
The problem is mechanical, Disassembly carefully the section mechanism, clean all with isopropilic alcohol and grease again.
Posted on May 15, 2009
Anonymous
  • 8 Answers
SOURCE: 2003 ford expedition, 6-disc cd player, several
try disconecting te battery that way the cd player would reset itself and probably eject the extra cd...
Posted on Feb 13, 2010
ABRsvcs
  • 4234 Answers
SOURCE: sa-pt760 get chnger error, disc tray
There is a mechanical problem with the changer. This is a relatively common failure that requires a "rebuild" and may also require a gear or two. The typical parts cost for this repair is under $20 and if I remember correctly, there is also an engineering change/modification that should be applied to this as well to prevent this from ocurring again. Since the rebuild requires a specific build order and alignment, this is NOT a DYI repair (unfortunately). Your best bet is to locate an authorized Panasonic service center for this repair.
Dan
Posted on Mar 22, 2010
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Panasonic 6 disc changer has suddenly stopped playing CD's and now shows E-1, E-2 and so on, messages while trying each disc sequentially, in my Opel Astra. I have tried the reset button to no ava
A CD may have gotten stuck moving from its slot to the play mechanism or while returning to its slot. If repeatedly pushing the reset button does not restore operation or make it possible to pop out the magazine, you may be in for a difficult task of removing the magazine manually but the stuck disc has to get unstuck first
Sep 25, 2012 | Car Audio & Video
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
Kenwood KDC-C662 6-Disc CD Changer - Error 'T99'
Hi....
Just accumulated dust can cause issues with the reader pickup
I'm not sure what T99 means but if you want to spend $35-90 to fix it,
it would be worth it.
Jan 06, 2009 | Kenwood KDC-C662 6-Disc CD Changer
Car MP3 player error
I believe that error 6 means incompatable disc format or disc read error.
Jun 12, 2008 | Clarion Car Audio & Video
CD's will not play
problem with the machine, it's either not reading the disk which would be a laser or the transverse motor or the mechanism isnt loading fully which could be a belt or a bad gear.
Dec 03, 2007 | Panasonic SC-AK75 Shelf System
Car Audio & Video Logo
93 people viewed this question
Top Panasonic Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Michael Thomas
Michael Thomas
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
