Question about Rival Kitchen Appliances - Others
I need help assembling rival meat slicer 65301
Posted by Carol Pfister on
1 Related Answer
Alex
  • 387 Answers
SOURCE: Rival slicer model #65301, sparks when I slice meat, need a new motor ?
not necessarily, you can clean the commutator (where the carbon brush is touching the rotor-where you see the sparks are coming from). you may want also to replace the carbon brushes if worn out
Posted on Oct 05, 2015
Where can I get replacement rubber feet for rival meat slicer model 1025v
See if the following suits your slicer:
HOBART or RIVAL FOOD SLICER Replacement SCREW IN FEET RUBBER PAD or...
The slicer predates 2014. Sears parts division has offers some Rival replacement parts. You might try them if the above source does not pan out. There is also a heritage parts outfit that might have something. The ebay listing for this part in particular does not list any as currently available. But one on the above leads may help.
Aug 04, 2018 | Rival Kitchen Appliances - Others
Need the blade retainer screw for the Rival model 1030-6 meat slicer
If the need is for a Rival 1030Vx series slicer, contact [email protected] for the threaded shaft and other parts, some new, some recycled. Available as of 8/17/17, several recycled threaded shafts in stock.
Jun 01, 2017 | Rival Kitchen Appliances - Others
Bolt and washer for rival meat slicer mod 1101e/3
I have these parts available as of 8/17/17, several recycled parts in stock. Contact [email protected] I also have blade washers and suction cup feet of recent manufacture.
Dec 23, 2016 | Rival Food Processors
possibly not as sparks can be from low brush length or the armature needs a clean up
all brushed motors spark when they run and normally it is a small blue spark the full length of the brush and contained under the brush
If it is a harsh arc like spark then the motor should be looked at by an appliance repair shop
Oct 05, 2015 | Kitchen Appliances - Others
I have a rival electric food slicer model # 1030/7. i need the part that holds the blade to the slicer to be able to cut the meat i want to cut. i hope that you can help me. i have been every where...
Rival changed methods of blade attachment over the years, even within the same model designation. If what you need is the one or both of the pieces illustrated below, I often have salvaged parts. Ask for Threaded Shaft or Thumb Nut (two styles, interchangeable) or both,
. rival-electric-food-slicer-model-vtdpjfyeb3b45iy5l4cxbybs-3-0.jpg rival-electric-food-slicer-model-vtdpjfyeb3b45iy5l4cxbybs-3-3.jpg
Jan 13, 2011 | Rival Food Slicer
Rival Meat Slicer Model 1037 Pin for blade
i too need a pin for this modle. has anyone solved this problem for that person?
Nov 21, 2009 | Kitchen Appliances - Others
Have a used food/meat slicer model#1101E/3
yeah right, for $12.99 I'll give you one answer Ha!
Oct 08, 2009 | Rival Food Processors
I need to know where to get a meat slicer tray?
I also bought one at a yard sale, complete and in the box. It did not have a meat tray with it, nor a picture of one on the box, nor any mention of one in the instructions. I just use a plate, and it works fine. Sorry.
Best regards, --W/D--
Aug 08, 2009 | Rival Food Processors
Kitchen Appliances - Others Logo
168 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
