SOURCE: I don't get sound from
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
SOURCE: need help connecting to surround sound to a vizio
hi,
did u mean connecting the sound bar to ur tv.
u didn't mentioned the model number of ur sound bar.
any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices.
if u are using a satellite receiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input.
ok
SOURCE: new vizio tv and vizio
get to your menu on the tv and click your audio, go down to speakers and turn it to the off position.
SOURCE: HOW DO I CONNECT MY TOSHIBA TV TO A VIZIO SOUND BAR?
Take it back to where you brought it from, End get your money back. End get a sound bar with a optical jack on it,
