On lower freqs, where tx is not allowed, nothing happens, just as meant. Not booting. Does it take too much current somewhere?
SOURCE: doesn't boot up
I think you cmos battery is dying... try to replace it.. and configure your cmos bios at exact date and time...
SOURCE: HT 1000, MT1000, Radius P110 Tx problems
Sounds like if you had them reprogrammed you might want to look at the "Transmit Shifting" A few years ago the FCC changed the shifting on somebands to tighten them up. Also if your not running a repeater and someone programmed it to shift in transmit then that, can be a problem. Also if your radios are programmed with a PL transmit and receive tone and they don't match then that's a cause.... If you can give more information on what frequencies, PL's, repeater your using would be a great help. Example.... Transmit 468.500, Receive 463.500, PL transmit & receive tone 100.
A slip of a number or PL tone will cause you a headache....
SOURCE: CLS 1110 Programming
Not certain what order you are doing it, so I will type a brief explanation:
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming.
SOURCE: Cobra 200GTL: Clarifier affects TX
Unfortunately, most people look to unlock the clarifier in radio's it is locked in.
From what I understand it is possible to lock it in that radio, however I do not know it because I usually unlock it in my radio's.
I also did a search, and asked a few people I know who are also very good with radio's and they do not know either. The only thing I found was this, and you have to pay this shop to do it.
http://cobraworxshopz.com/12.html
SOURCE: Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
