Question about Tomtom GPS
How to Fix Error Related to MyDrive Connect after application installation?
If you are searching the guiding platform to troubleshoot the error associated with MyDrive connects that appeared later to application installation on Tomtom device. Then you may try the following steps: • In the first step take initiative to the reinstall the latest.Net Framework • In the second step, follow the process to uninstall Tomtom Driver • Thereafter prefer to uninstall MyDrive Connect • Restart your PC once again and turn on the automatic updates option Apart from executing these steps, still you find the trouble then call our 24/7 hours available Tomtom Map Updates Tollfree number +61 1800 215 732 Australia to approach for quick and effective solution service.
Posted by Teresha Palmer on
1 Related Answer
Anonymous
SOURCE: Upload latest western europe map v7.20 to TOMTOM 700 not possible
I have managed to solve the problem of loading a new map on my Go700 using a Mac. I discovered that Tomtom is incompatible with the Leopad operaying system, despite the protestations of the idiots at Tomtom ,so I reverted to an older Mac using Tiger.
Taking the instructions given to crinold, I tried to erase the disc on the 700 using home 1.5 - and it didn't work. So I went to disc utilities, highlighted and erased the Tomtom disc, and opened home 2,5. After being refused entry several times, like being told to load an already loaded device, I persevered, and managed, slowly, to add the map I had bought for 78 euros. T]One point oif interes is that when I bought the map, they site stated it would cost 63 pounds sterling, but switched it to euros when the invoice arrived. at a rate very favourable to Tomtom - funny, that.
This is sharp practice,probably illegal in many countries,, but, to be honest, dealing with the mysterious Tomtom company is so frustrating, that I don't have the time or inclination to fight them for the money they cheated from me.
How they survive with such an awful product and extremely bad after sales service is hard to understand - perhaps they won't ... we live in hope.
Posted on Mar 19, 2009
Just bought a VIA1505M tomtom and need to get started. how do I get maps installed
you need to install software on your computer .
called mydrive connect
https://www.tomtom.com/en_au/mydrive-connect/
http://au.support.tomtom.com/app/answers/detail/a_id/13855/locale/en_AU
tom tom via is listed as supported by mydrive connect
Then buy the maps from tom tom .
However it should have some sort of map in it already ?
May 02, 2017 | Tomtom GPS
Update 1st time
Make sure that you are using the latest version of MyDrive Connect.
Connect your navigation device to your computer and switch on your device.
MyDrive Connect starts and automatically checks if a newer version of your map is available. If you are entitled to the Latest Map Guarantee, MyDrive Connect offers you the latest map.
Click Continue and follow the on-screen instructions to download and install the available map.
Once the installation is complete, the installation screen will close and you are re-directed to the My Content page. Also, the status in MyDrive Connect changes to Connected.
When you see the MyDrive Connect icon on your computer and the message on your navigation device that the installation has completed, disconnect your navigation device from your computer.
your device has been updated
Apr 18, 2015 | Tomtom Start 20 Europe
How to fix error message; Error in actiom 3: file of application c:\atscallingcard\install\atshotket.exe
Do you use the ATS calling card application?
As the error message is related to ATS calling card application, I would suggest you to uninstall and reinstall that application (if you still use it) and then check if it works.
Uninstall or change a program
http://windows.microsoft.com/en-us/windows/uninstall-change-program#uninstall-change-program=windows-7
Sep 27, 2014 | Dell Computers & Internet
What is error 0x80029c4a and how i fix it
0x80029c4a is often related to a MS library error.. it can't load the correct library. There are various ways to try to fix this error depending on the software/application your using.. (most commonly this issue occurs with outlook) If your running the 32 bit version on top of a 64-bit platform you can try running the 64-bit application instead of the 32-bit. You can also try re-installing the application to see if that fixes the error. Without knowing the exact application version & any other problems you might be having thats all I can advise at the moment.
Nov 06, 2013 | Computers & Internet
System error &H80040111 (-2147221231)
Try installing your .NET frameworks and other Windows related runtimes.Also try re-installing the complete Microsoft Office package
Jan 28, 2012 | Microsoft Office Computers & Internet
I've tried for several days to connect to Kodak Easy Share and always get the message: has encountered a problem and needs to close.
Either the software is corrupted or is not compatible with your Operating System.There might be problems with your hardware device also (Kodak Device). First of all when the error occurs we have to find why this error occurred. We have to get more details about it. To do so: We have to examine the Error Logs.
  1. Please click on the Start Menu. Type Run in the search box - in Vista - or click on Run - in Windows XP.
  2. Type this and hit enter key. Eventvwr.msc
  3. Go to the Application Category. Check for errors (Red oval with X on it). If there are errors - see the details - for the Application please post it here. You can read the messages and understand which Application that the error is related with. Check the Date and Time values to verify that it is the exact error related to this software.
  4. Then go to the System category and check for errors related to the System if you have connected the Device to the PC. If exists please let us know.
Solution: e easiest solution is to uninstall the software and re install. Download the recent version from here. Note that Apple Quick time is required by the application. Download it from here. Installation Instructions and Operating System Compatibility - Now compatible with windows 7 as well.
Please rate the answer as well if it helps you to solve the problem.
Thanks for contacting Fixya!
Jul 08, 2010 | Computers & Internet
Hello sir i cann't sign in to msn messanger whenever i try to sign in is shows me that windows live communication platform i think that there is a data error wlcommm.exe
1: press ctrl alt + delete
2: select the task manager
3: search for all related messenger programs/tasks
4: end them
5: restart messenger
good luck ; )
Apr 22, 2010 | Microsoft MSN Messenger Connect Service
Error 8007007e
i think we need to uninstall the SP3 for windowsXP
Mar 21, 2009 | Microsoft Windows Live Messanger
JVM error 102
You are experiencing a fatal error with the java platform or one of the.cod files have corrupted. You will need to reinstall your blackberrys software.
  1. Connect the handheld to the desktop computer and start the Application Loader.
  2. Re-install the BlackBerry Handheld software.
perform a clean reload of the BlackBerry DeviceSoftware on the BlackBerry smartphone using the application loadertool. For instructions, see here for entire instructions
Mar 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
Mar 29, 2008 | Microsoft Windows 98 for PC
GPS Logo
107 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
