Question about Nokia Cell Phones
How to Fix Nokia N72 back cover slider mechanism?
Posted by mohit arora on
My nokia n72 mobile was fell into water and..not working and mobile mechanic also given up what should i do now.
Water damaged the motherboard of your N72 that's why it is not working.
Instead of taking it to mechanic take it to Nokia care center.
They will surely sort this out.
Jun 21, 2011 | Nokia N72 Cellular Phone
Nokia N72. The camera is not working, every time I try using it, I get the message, camera on standby, open lens cover. Please help.
you can chang your phone body.
because your phone back body is loosed so the booten can't touch.
chang body and use..........
Nov 22, 2010 | Nokia N72 Cellular Phone
How to open the mobile N72
First open the back side cover for the battery and then remove the battery and SIM. Now you can open the front cover and the keypad very easily by just pulling.
Sep 09, 2010 | Nokia N72 Cellular Phone
HOW I CAN OPEN THE COVER OF N72
Press on hold the back cover on the back of the phone and slowly slide it out.. If phone is new it would normally take some few extra muscles to slide it out
Aug 11, 2009 | Nokia N72 Cellular Phone
I want to change sim card in my nokia N72
Dear
I think u have some problem with removing back cover of ur phone
To change sim card follow below instruction
1) Turn off your mobile phone (press switch off button on top of the phone)
2) Remove back cover by pressing unlock button on the cover & slide cover upwards gently (please take care you would not force the camera cover)
3) Remove Battery From the phone & u will see ur current sim or sim slot
4) Check instruction & insert your sim
Thanks
Mar 30, 2009 | Nokia N72 Cellular Phone
Hi,I have the n95 and the slide is very stiff when i open or close it. can you please tell me why? and the solution to fix it. Thanx in advance, Al.
Two solutions here. Don't try the second one if your phone is still under warranty or if you're bothered about invalidating the warranty. 1) Take your phone to a Nokia service centre, it should be free of charge to fix. 2) With the slide open, from the sides of the numerical kepad, carefully prise the back cover off, if you have thumb nails this is really easy. Spray a small amount of silicone spray, NOT wd40 as that attracts dust, onto a cotton bud, the type that would be used to clean ears, and dab the spray on the runners that are visible with the cover off. As you are applying it, keep moving the slider to spread the silicone spray along the whole mechanism. Do this on both sides. The rear cover will just click back in place.
Hope this helps.
Mar 06, 2009 | Nokia N95 Cellular Phone
N72 batary replacement guide
Hey,
user manual for your n72 is here
http://nds1.nokia.com/phones/files/guides/Nokia_N72-5_UG_en.pdf
Replaceing the battery is really easy, open the battery cover in the back, take the battery out.
Let me know if you need anything else.
Thanks,
Ekse
Feb 24, 2009 | Nokia N72 Cellular Phone
Unable to connect with system
u can connect by taking away the back cover of your mobile and then connect it by putting the back cover a side
Nov 11, 2008 | Nokia N72 Cellular Phone
Hi Iam unable to connect my Nokia N72 to System... when i am trying to Insert USB to the Port it is not taking any action... Kindly *** the needful...
to connect do 1 thing. which i did, open tha back cover of your mobile and put it on a side then enter the usb cable with nokia pc suite then it will work
Cell Phones Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
