SOURCE: Yamaha M-65 Stereo Power Amplifier This
Try first unplugging power cable for five minutes , see if it reset.
SOURCE: Crown XLS402 amplifier will not work
It is probablly in protect mode due to a failure. This prevents blowing your speakers.
You will need to have or do servicing on it. First verify that you can unplug ALL INPUTS and that speakers are connected and problem of the protect LED exists. A bad input MIGHT be causing this due to a ground loop.
Make sure NONE of your speaker leads are grounded or shorted.
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Thank you for using Fixya
